Thermostat housing
Thermostat housing
Postby graham » Sun, 08 Apr 2012 8:41 +0000
I over tightened one of the nuts for the thermostat housing and sheared it off. Anybody know where I can get a replacement and how to get the bit that's stuck out? I was think of some WD40 and a pliers as there is a good chunk sticking out.
G
graham
Re: Thermostat housing
Postby Steve » Sun, 08 Apr 2012 10:35 +0000
vice grips should do it, bring it in with you to a local hardware for a replacement.
Postby shaneh » Mon, 09 Apr 2012 7:17 +0000
http://www.mx5parts.co.uk/thermostat-housing-p-774.html
i had to buy 1 aswell.
not cheap but its good quality
shaneh
Postby sidewaysreilly » Mon, 09 Apr 2012 10:32 +0000
can it be drilled out???
Postby graham » Sun, 15 Apr 2012 12:35 +0000
It just wont budge, the stub is starting to get a bit wrecked with me trying to get it out. Any tried and tested suggestions?
g
graham
Postby sidewaysreilly » Sun, 15 Apr 2012 6:48 +0000
yeah, drill it and use an easy-out. If you take the housing off ill do it for you.
Postby graham » Tue, 17 Apr 2012 1:25 +0000
If only it was that easy... You need to remove the timing belt to get at the housing, taking it off would be fine, putting it back on would be an issue!
g
graham
Postby sidewaysreilly » Tue, 17 Apr 2012 7:03 +0000
whare abouts are you?
