Clunking sound from Drive shaft
Postby Schmoo0_0 » Tue, 29 May 2012 9:45 +0000
Hi, has anyone come across a 'clunking sound' from mid point under the car (97 Mk1) when you hit throttle? I suspect it is the drive train/shaft. Garage said not major problem but it would be nicer to have a smoother response from acceleration (power is OK) and gear changes
Schmoo0_0
Postby mx5ash » Tue, 29 May 2012 10:53 +0000
Would it be ware in the u joint?
Re: Clunking sound from Drive shaft
Postby leamyj » Sat, 02 Jun 2012 12:49 +0000
More than likely what Ash says, you could pick up a replacement shaft hand enough, probably cheaper than trying to replace the universal joint.
Postby 93 Mk1 » Sat, 02 Jun 2012 3:13 +0000
I had this problem with my first MX5. Once it started it got progessively worse. I dropped the prop shaft and it was
indeed the universal/harvey spicer joint that was the problem. As the lads mentioned, it's cheaper and saves hassle
to get a good used replacement shaft and fit that. I think I bought mine from Autolink UK for around £30 at the
time.
93 Mk1
Postby MX5Spares » Mon, 04 Jun 2012 11:25 +0000
autocheck have them for 40e and 50 e for shorter type 1.8 open all weekend
Postby MX5Spares » Mon, 04 Jun 2012 11:46 +0000
phone autocheck 086 8226506 please
Postby Schmoo0_0 » Wed, 06 Jun 2012 9:06 +0000
Thanks guys... showing my ignorance here! It was actually the spare wheel not being screwed down enough & clunking in a gear change!!
I am selling her anyhow as I need a 4 seater for impending arrival. If you know of anyone interested, she is spotless. Negotiable on price & found here: http://cars.donedeal.ie/for-sale/cars/3425480 Thanks again
Schmoo0_0
Postby 93 Mk1 » Fri, 08 Jun 2012 1:35 +0000
Tidy looking car. Best of luck with the sale.
93 Mk1
Postby Schmoo0_0 » Sat, 09 Jun 2012 12:38 +0000
Thanks. They dont shift (rather Sell) easy so I am open to negotiation. Want to see it in a good home really!
Schmoo0_0
