Postby james » Mon, 10 Sep 2012 12:37 +0000
thanks will have to get that kit myself some time both boots are cracked
james
Postby sifpilsen » Mon, 10 Sep 2012 1:26 +0000
Fitted hardtop side mounting plates from mx5parts. Now the car feels like a coupe with the hard top on. Looks good too.
Filled up clutch fluid again, as the reservoir was empty. I know there is a leak somewhere, just have to find where.. Brakes holding up fine.
x-'91 1.6
x-'94 1.8
sifpilsen
Postby Steve » Mon, 10 Sep 2012 5:37 +0000
Might be the slave cylinder, pull back the boot and see if there is fluid underneath.
Postby sifpilsen » Mon, 10 Sep 2012 11:26 +0000
Will have to do. The master cylinder is a bit rusty. Any good pictures where the slave cylinder is placed?
Also changed spark plugs and leads. 8mm Black ones from mx5parts, turned out a tad long. They do not lie flat on top of the top gasket cover, but they work. Slight smoother operation.
x-'91 1.6
x-'94 1.8
sifpilsen
Postby Steve » Tue, 11 Sep 2012 12:27 +0000
Look in through the drivers side wheel arch and you'll see it bolted to the gearbox.
Just two bolts and the line to remove. Would recommend undoing the bolts from below (to get a good swing at them).
Some pics linked in this thread : viewtopic.php?f=21&t=3282&p=30075&hilit=slave+cylinder#p30075
Also, heres how I changed the master cylinder (I didn't "bench bleed" it and it has been perfect):
http://mx5ireland.com/tech/clutchmaster.html
Postby peteh » Thu, 13 Sep 2012 1:22 +0000
Fitted a set of retro side repeaters I got on an MX5Nutz group buy, based on ones from an Alfa I believe!
peteh
Postby james » Thu, 13 Sep 2012 2:06 +0000
retro side pimples =]
james
Postby peteh » Thu, 13 Sep 2012 7:26 +0000
to go with the ones the driver has! ha ha
peteh
Postby Steve » Tue, 16 Oct 2012 6:46 +0000
Painted + fitted a "Dustpan" intake.
Rewired fog light relay, painted bonnet strut and replaced the rear slider pins, they were in a bad state.
Postby rhysmate » Wed, 17 Oct 2012 8:57 +0000
Steve wrote:Painted + fitted a "Dustpan" intake.
whered you get your intake? i like it nice and tidy...
rhysmate
Postby Steve » Wed, 17 Oct 2012 10:22 +0000
Its a GReddy intake, I think I sourced it via one of the US forums. Flyin' Miata used to sell them/incl as part of the FM turbo package so there should be a few knocking about in the classifieds.
Postby rhysmate » Wed, 17 Oct 2012 11:32 +0000
it looks tidy... are you bringing the car on sunday?
rhysmate
Postby Steve » Wed, 17 Oct 2012 2:04 +0000
Yep will do
Postby Medic5 » Fri, 19 Oct 2012 2:06 +0000
Brought car to NCT centre and ............. It passed, 11,000 since this time last year, no service since! Figured I'd throw it in for test & fix whatever it failed on! Clear bill of health :-)
Postby shenab » Fri, 19 Oct 2012 4:35 +0000
Well done PJ about time you had some luck with the 5
- Albert Einstein
shenab
