Failed Nct
Failed Nct
Postby fierymx5 » Tue, 11 Sep 2012 8:15 +0000
Any one got a set of cheap rims with decent tyres just need em to pass Nct apparently my wheels are too wide (load of shite) any thing considered thanks lads
Wayne
fierymx5
Re: Failed Nct
Postby kieran » Tue, 11 Sep 2012 9:23 +0000
whats your location
kieran
Failed Nct
Postby fierymx5 » Tue, 11 Sep 2012 10:18 +0000
Based in graiguenamanagh co Kilkenny but am in the city nearly everyday
fierymx5
Re: Failed Nct
Postby kieran » Tue, 11 Sep 2012 10:22 +0000
too far away id give u a loan of a set
kieran
Failed Nct
Postby fierymx5 » Tue, 11 Sep 2012 10:29 +0000
No panic Kieran thanks for the offer tho
fierymx5
Re: Failed Nct
Postby rhysmate » Tue, 11 Sep 2012 10:31 +0000
Why were they too wide? Tread sticking out?.
rhysmate
Failed Nct
Postby fierymx5 » Wed, 12 Sep 2012 7:45 +0000
No that's what I thought as well but the thread is clearly under the arch.the tyre might be a little stretched but the rim sticks out a bit il upload a photo later haven't got any on the phone at the moment. Went looking in the Nct manual last night and can't find anything about failing because the tyres are too wide wudnt mind but my fronts are just as big and it's only the back he has a problem with
fierymx5
Failed Nct
Postby fierymx5 » Wed, 12 Sep 2012 7:46 +0000
fierymx5
Failed Nct
Postby fierymx5 » Wed, 12 Sep 2012 11:06 +0000
Best pic I could find of the rear Image
fierymx5
Re: Failed Nct
Postby scallan » Thu, 13 Sep 2012 11:07 +0000
mine are simmilar and didnt have a problem with n.c.t
scallan
Failed Nct
Postby fierymx5 » Thu, 13 Sep 2012 12:43 +0000
I'm so pissed off with em they said all four shocks were loose as well.but yet when I looked this morin their all ok. I think when he raises the car the springs drop down because the cars lowered and they look like their loose on the coilover my heads in a heap trying to sort all the crap from em thinking might try test it in another centre Image
Image I don't think they really stick out that much
fierymx5
Re: Failed Nct
Postby scallan » Thu, 13 Sep 2012 2:23 +0000
no they aint last time i tested mine i had 15x8 et 10 on the back and 15x6 et38 on the front no problem but ya i found the test centre in arklow alot better than enniscorthy
scallan
Re: Failed Nct
Postby leamyj » Fri, 14 Sep 2012 7:00 +0000
are the NCT not required to explain to you EXACTLY why they fail a vehicle???
Failed Nct
Postby fierymx5 » Fri, 14 Sep 2012 8:29 +0000
Yea the problem with the wheels are they stick out to much.he the told me all the springs were loose on the car but I went around em all yesterday and cudnt find a problem wit them at all . Wudnt mind when I removed the two back wheels the inside of them were nearly bald from the camber in the car and the sidewall was cracking and he never even seen that
fierymx5
Re: Failed Nct
Postby rhysmate » Fri, 14 Sep 2012 8:37 +0000
they will fail you if the springs are loose when the car is up anywhere man.. just wind the adjusters up until the springs are tight and get a set of standard wheels from somewhere. they can be your ''nct wheel''.. i know a man in limerick who has loads of standard wheels with tyres
rhysmate
