Postby paulc » Tue, 15 Jan 2013 11:53 +0000
Try four chrome exhausts, still worth every minute of it, Oh happy days.
paulc
Postby Steve » Tue, 22 Jan 2013 12:33 +0000
replaced the license plate lights brackets, they were badly rusted through:
New ones in and working
Postby james » Tue, 22 Jan 2013 11:06 +0000
proper nasty
james
Postby Medic5 » Fri, 01 Feb 2013 2:44 +0000
Taxed my 5 for the next three months :)
Postby back_in_black » Fri, 01 Feb 2013 10:33 +0000
Changed my dash lighting and set the timing to 14 degrees this evening. Only had a quick spin but seems to have a bit more pep at lower revs.
Old dash lighting with the green covers on the bulbs
Tried out some red bulbs but you'd need to take the green filter off the back of the dials to get the right result
Went with new clear bulbs and happy with the result. Have a dash light dimmer switch on the way from Robert to finish the job.
back_in_black
Postby barney » Sun, 03 Feb 2013 10:16 +0000
changed coolant in both the 5 and the Audi 80. I'll do the oil in both the next decent day that comes. NCT booked for the 5. Can't get a date till april 3rd but have asked for a cancelation and hopefully get it within a fortnight.
Postby peteh » Thu, 07 Feb 2013 9:34 +0000
had a go at modding my instrument binnacle with some new dials, stainless steel surround, dial rings and needle caps and painted my needles red...
peteh
Postby back_in_black » Thu, 07 Feb 2013 10:44 +0000
Nice work!
Will you have to calibrate the new needle postions? or can you just "pop" them on?
back_in_black
Postby peteh » Thu, 07 Feb 2013 11:20 +0000
pop them on, dead handy :-)
peteh
Postby snowman » Fri, 08 Feb 2013 6:51 +0000
I know this is an old topic, probably not on here, but i decided to go a little further.. :think:
I wanted to put a front fog light switch in my MK1 but didn't want to use another switch location on the dash.
So i saw a posting on the OC forum, think it was from M-m, about using a MK2.5 double switch.
Also acquired a heated seat switch, as i wanted to butcher it for parts
The fog light switch only has 1 lit up, i wanted to be different... :D
So i drilled holes in the front switch so it would accommodate the clear perspex from the heater switch
Its not wired into the car yet, as you can see from the pics, but i will try to get it done soon :wink:
Just need to finish it off and hope for some good weather ....
Before anybody mentions it, i know the colours are different, makes it easier to see which is on :-D
Does anybody know what these bulbs are?? both of them would help..not in need of them yet, just to keep it mind if they blow, as one has already gone :sad:
They are out of the switch
Love my 5
Running on LPG
Should have got one sooner!!
snowman
Postby back_in_black » Fri, 08 Feb 2013 10:07 +0000
Hi Snowman
The mazzda part no. NA01-66-462 and the LED version is NEO3 available from http://www.superbrightleds.com/
Hope this helps
Alan
edit
Sorry it could also be Mazda BR7055431 or LED NEO4.
Its hard to tell from the photo but if you have a spare hazard/lights up switch the bulbs in there are the the first ones above (check if its the same bulb) but I think the the switch one might be a bit smaller and then its the second option.
back_in_black
Postby gunners5 » Sat, 09 Feb 2013 12:25 +0000
Nice work Peteh on the instrument binnacle, thinking of going the same route myself.
Whats the quality of the dials like?
gunners5
Postby peteh » Mon, 11 Feb 2013 12:25 +0000
gunners5 wrote:Nice work Peteh on the instrument binnacle, thinking of going the same route myself.
Got the dials from a guy on mx5 nutz, you'll find him in d group buy section, quality is excellent and he's great to deal with, he can do any design u want, thumbs up from me
peteh
Postby peteh » Mon, 25 Feb 2013 12:43 +0000
fitted a stainless steel cover piece to the heater controls to match in with the jass instrument binnacle surround
peteh
Postby s-mac » Mon, 25 Feb 2013 3:06 +0000
Pete what vent rings are those? They look good, never really liked mine
s-mac
