LHS indicators all out
Postby shenab » Sun, 05 May 2013 11:08 +0000
Hi guys
All bulbs good and at the start it seemed intermittent
Any thoughts of what the issue would be?
Shena
- Albert Einstein
shenab
Re: LHS indicators all out
Postby MX5Spares » Sun, 05 May 2013 12:49 +0000
Hi Sheena'. Probably best o check fuses ar drivers knee area 'nust pop off the cover and each fuse should be marked on the inside of the cover. Only replace fuse if blown with one of same size ie 10 amp etc.I f it is blown and you do replace and it goes again there is a wiring fault or possibly bad connection at one of the indicator bulb holders. If you call me I can explain handier 086 8226506 Robert
Postby shenab » Sun, 05 May 2013 1:43 +0000
Hi Robert
Sorry should have said all fuses checked too
Shena
- Albert Einstein
shenab
Postby MX5Spares » Sun, 05 May 2013 4:25 +0000
Ok well then possibly switch ,especially if opposite side is ok its hardly the flasher unit. Did u try the hazard lights to see if all indicators are working on hazard as this will eliminate some areas. If you ant me to look at it some evening I can try a few things
Postby shenab » Mon, 06 May 2013 5:14 +0000
Hi Robert
hazzards not working but indicators flash when alarm turns on/off .. that's odd right but perhaps points to where the problem is? relay maybe?
Shena
- Albert Einstein
shenab
Postby MX5Spares » Mon, 06 May 2013 6:36 +0000
looking like hazard switch but if you drop out we can try one.
Postby shenab » Tue, 07 May 2013 4:51 +0000
Hi Robert
I will get out to you some evening
Thanks a mil
Shena
- Albert Einstein
shenab
