Aerial Wanted
Aerial Wanted
Postby Quinlanar » Wed, 08 May 2013 9:26 +0000
Im looking for a bee sting aerial for my NA
94 Eunos roadster 1.8
Quinlanar
Re: Aerial Wanted
Postby MX5Spares » Thu, 09 May 2013 3:23 +0000
What's a bee sting aerial? Straight mast ??0
Re: Aerial Wanted
Postby Quinlanar » Sat, 11 May 2013 10:59 +0000
my aerial was taped up just checked there today that i have the automated one and its broken, it makes noise like it sounds like it should work just the aerial wont extend, how much are they to replace
Quinlanar
Re: Aerial Wanted
Postby MX5Spares » Sun, 12 May 2013 8:47 +0000
Usual problem, The plastic gear on the end of the mast are worn so motor is turning. But no drive. Check it out butbI think mast section is about 45 e.. We have one only good electric aerial complete fotr 60 e
Re: Aerial Wanted
Postby franksm » Sun, 12 May 2013 9:02 +0000
I changed the mast on the electric aerial on the Jag, it was pretty easy - it just slots in with a bit of careful timing as the mast has a toothed section on the bottom. The MX5 is similar, it appears. I picked up mine for £15 on ebay.
Here's a scary guy showing how to do it: http://www.youtube.com/watch?v=VvqJRR7iBLE
This one's better but not 100% relevant http://www.youtube.com/watch?v=a3RZca7Zkr4
Re: Aerial Wanted
Postby MX5Spares » Sun, 12 May 2013 11:05 +0000
15 e is great price. Autolink are something like 40 sterling . Must check it out
Re: Aerial Wanted
Postby franksm » Sun, 12 May 2013 11:21 +0000
Yeah, "car-masts-uk" is the vendor. This is what I got: http://www.ebay.co.uk/itm/JAGUAR-Aerial ... 5d2624d9be
Just checking now, he doesn't have ones for MX5s at the moment on ebay, but you get the idea... I wonder are the masts generic, because the motor just grips the toothed end of the mast and goes up or down to the extent of the mast's travel ?
Re: Aerial Wanted
Postby MX5Spares » Sun, 12 May 2013 3:55 +0000
I have damaged mast for measurments if that helps.
Re: Aerial Wanted
Postby Quinlanar » Sun, 12 May 2013 8:21 +0000
think ive identified the problem, there is no nylon wire running through it, thanks for your help
Quinlanar
