Postby fez » Thu, 05 Dec 2013 5:41 +0000
not today but last weekend.
Changed brake caliper, broke pop up light.
Next weekend,
Fix light, NCT, pass NCT, most likely break something else.
fez
Postby leamyj » Fri, 06 Dec 2013 5:48 +0000
fez wrote:not today but last weekend.
Next weekend,
:mrgreen: :mrgreen:
Postby scallan » Fri, 06 Dec 2013 7:48 +0000
Not today but over the past week
Removed aircon
Depowered steering rack
Fitted hydro handbrake
Fitted poly diff bushes
Stripped interior
scallan
Postby Randy » Fri, 06 Dec 2013 8:12 +0000
scallan wrote:Not today but over the past week
Removed aircon
Stripped interior
Is it a big job removing the air con?
When I go turbo I'm going to be looking for a bigger rad also, and might want the extra room.
Randy
Postby scallan » Fri, 06 Dec 2013 8:22 +0000
It was handier than i thought but i done it on a mk1 im only after buying for the track but would assume its simillar on a mk2
scallan
Postby sidewaysreilly » Sat, 07 Dec 2013 4:02 +0000
Whats the steering like now?
Postby scallan » Sat, 07 Dec 2013 4:43 +0000
Feels very heavy when stopped or slow but feels alot better when moving fast can feel the road alot better
scallan
Postby andrew » Sat, 07 Dec 2013 10:07 +0000
Removing the air con is quicker than you think, you can easily fit a intercooler in with the a/c rad too.
I have to say I think the power steering in the mk1 is the best in any car I have driven. Its one of the best parts of the car, mine see's a lot of track action too.
andrew
Postby scallan » Sun, 08 Dec 2013 12:56 +0000
Ya i only removed mine because im planning on a few drift days and want to fit extra lock aswel which i have head will fuck up the seals in the rack. I had the car out a few weeks ago in a big yard seeing how it would go and ended up covering the front end of the engine bay in power steering fluid out of the resivior.
scallan
Postby andrew » Sun, 08 Dec 2013 5:00 +0000
that make sense, overflowing p/s fluid is common when on track. I keep my resevoir at the min and it still boils. A bigger cooling loop could solve the problem too. Extra lock sounds good, especially for drifting.
andrew
Postby scallan » Sun, 08 Dec 2013 6:18 +0000
Ya hopefully it works out now because the mx5 seems to hit the standard full lock very easy
scallan
Postby Steve » Mon, 09 Dec 2013 12:39 +0000
did you loop the lines and remove the seals?
Postby scallan » Mon, 09 Dec 2013 1:44 +0000
I followed this tutorial on flyingmiata. Its was alot easier than i thought it was going to be http://www.flyinmiata.com/tech/depower.php
scallan
Postby sidewaysreilly » Mon, 09 Dec 2013 8:25 +0000
All very well but they didn't weld up the valve on the pinion shaft so your gonna have a wee bit of play remaining.
To do it properly you must do this..........
http://www.motoiq.com/MagazineArticles/ ... -Rack.aspx
Postby scallan » Mon, 09 Dec 2013 9:04 +0000
Awh it will do me for the time being see how this goes now mite do this later on
scallan
