Someone to fit rear window on soft topWould anyone know any place that could fit a rear window for me, I have a slit in my window and have a replacement but it will need to be sewn on, anywhere around Munster would be best but il go further if I need
Re: Someone to fit rear window on soft topHello Kieran
Do you know of any place where they mend/make sails for boats ,seems to me to be the same materials ie heavy canvas ,plastic etc.would it be an idea to glue the window in using silicone sealer ,save the sewing . Would only work if the window is bigger than the opening Good luck with it Brian ]96 na Merlot edition. sold
Is it plastic you putting? Icon
RS Mk1
Re: Someone to fit rear window on soft topYa it's a plastic window replacement I have
I've heated glass from my old roof if you want. Icon
RS Mk1
Thanks, I might even have one of them spare myself, it's just the sewing of the plasticwindow onto the roof is where I'm stuck unless I do something like what Brian was saying and glue it on with a really strong weatherproof glue 1990 Eunos Roadster 1.6: cusco coilovers, carbing front and rear strut braces, 1.8 brakes, performance engine and diff mounts, stage 2 cerametalic 6 puck 1.8 clutch with lightweight JUN 1.8 flywheel, 1.8 LSD, GReddy manifold, Garrett T25 turbo, ARTech down pipe, E-Manage blue ecu, Altezza injectors, FMIC. Zoom engineering center console, carbon fibre bonnet, garage vary front lip, lightweight garage hundred one hardtop, carbing 6 pt cage.
No problem. Have one so thought I'll offer. Ya..Brian could be the wise man here..I would say that would be the easiest way.. Anyways good luck and let us know how you got on. Icon
RS Mk1
Re: Someone to fit rear window on soft topI know a place just off Blarney Street. On Google Street view you can see his number..
Nico
