Its in good condition no leeks or bad corrosion. Only the usual surface rust that comes off with a wire brush.
Exhaust tip needs a polish but is not damaged or corroded.
€25
 MK1 Standard Cat BackSelling my old Cat Back exhaust as I fitted a twin exhaust earlier this year and now have no use for it. Its in good condition no leeks or bad corrosion. Only the usual surface rust that comes off with a wire brush. Exhaust tip needs a polish but is not damaged or corroded. €25   Sent from my GT-I9505 using Tapatalk Last edited by AndyJF on Mon, 20 Oct 2014 10:06 +0000, edited 1 time in total.
   Re: MK1 Standard Cat BackWhat bore is it? ...in many ways, I'm a very bad man... Mk1 1.8 'G-Limited' Jap Roadster
   Re: MK1 Standard Cat BackIts the standard factory one. I think there 1.75 inch. Sent from my GT-I9505 using Tapatalk
 What year is your 5? ...in many ways, I'm a very bad man... Mk1 1.8 'G-Limited' Jap Roadster
   Re: MK1 Standard Cat BackIts a 1994. Should fit all MK1s as far as I know. Sent from my GT-I9505 using Tapatalk
| Who is onlineUsers browsing this forum: No registered users and 1 guest | ||
