Postby leamyj » Tue, 30 Sep 2014 7:03 +0000
Nice!
Postby Steve » Mon, 06 Oct 2014 9:47 +0000
its not an MX5 but its convertable, has MX5 seats and think I might be putting an MX5 engine and box into it
Postby Merlot man » Mon, 06 Oct 2014 2:56 +0000
Hello Steve ,
Thats looks like a nice car ,i assume its a kit, is it a dax or something like that ?
If your need any help working on it give me a shout would love to work on it .
brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
Postby Steve » Mon, 06 Oct 2014 4:36 +0000
Cool, will give you a shout, its a Madison Roadster, bit of an experience to drive at the moment :-)
Postby barney » Mon, 06 Oct 2014 10:57 +0000
I like the colour. :D Nice looking motor
Postby davith501 » Thu, 09 Oct 2014 2:05 +0000
Current intake setup. Still work in progress..will be trying different setups..
Lsd/gearbox oil change. Ngk spark plugs and ht leads in.
Tein coilovers and big brakes fitted.
Icon
RS
Mk1
davith501
Postby ger » Thu, 16 Oct 2014 11:00 +0000
@davith501 might be wort trying the air filter to the right of the washer bottle next to the firewall. This is a high pressure area and seems to be one of the cooler areas to locate an air filter. Messed around with a temp sensor measuring different intake positions and this was the best.
Postby davith501 » Sat, 18 Oct 2014 9:34 +0000
ger wrote:@davith501 might be wort trying the air filter to the right of the washer bottle next to the firewall. This is a high pressure area and seems to be one of the cooler areas to locate an air filter. Messed around with a temp sensor measuring different intake positions and this was the best.
Was considering going through firewall and getting pressurised air from there but drilling was my last option. It does make sense what you are saying..it's the corner that traps the airflow..good advice..definitely will try that next and thanks for that. Have you any thoughts on having it like this?
Icon
RS
Mk1
davith501
Postby Noel Heldsinger » Thu, 30 Oct 2014 10:57 +0000
I fitted a Pipercross induction kit and polished soft top. Sounds and looks great.
Noel Heldsinger
Postby ger » Mon, 01 Dec 2014 11:07 +0000
Fitted some mk2.5 seats to my mk1 (thanks robert) and made a nice office chair out of the old passenger seat, very comfortable, going to put a jack on the speaker wire and plug into the computer.
Postby gar07 » Tue, 02 Dec 2014 12:53 +0000
i under sealed my5 today :)
gar07
Postby Steve » Tue, 02 Dec 2014 1:34 +0000
ger wrote:Fitted some mk2.5 seats to my mk1 (thanks robert) and made a nice office chair out of the old passenger seat, very comfortable, going to put a jack on the speaker wire and plug into the computer.
Ha! Love it
Had to take apart my rear brake again yesterday as it was sticking, took the piston out a bit further and cleaned off the gunk + lube'd it up with brake fluid. Think I see a new piston being needed early in the new year.
Also took out the air intake temp sensor as it was causing boost cut/readings flicking up and down, turned out that the connector was oxidized all back together and readings now solid.
Postby Yolo » Fri, 05 Dec 2014 10:43 +0000
[quote="ger"]Fitted some mk2.5 seats to my mk1 (thanks robert) and made a nice office chair out of the old passenger seat, very comfortable, going to put a jack on the speaker wire and plug into the computer.
Love the office chair... Brill.
1992 Mk1 Eunos silver
Mk2 suspension
IL Motorsport bushes
Mk2.5 leather seats
1.8 brake upgrade
learning slowly
http://www.mazdamenders.net
Yolo
Postby Real Rayzor » Sat, 06 Dec 2014 11:57 +0000
Replaced the fuel filter on my MK 2.5... Pig of a job. Those fancy connectors were very hard to get off. Got their in the end though with a bit of swearing and fiddling.
Real Rayzor
Postby Real Rayzor » Tue, 06 Jan 2015 11:55 +0000
Refurbished all 4 wheels . Not a great job but definitely better than what they were.
Real Rayzor
Users browsing this forum: No registered users and 27 guests
