Users browsing this forum: No registered users and 27 guests
Re: What did you do to your MX5 today ?its not an MX5 but its convertable, has MX5 seats and think I might be putting an MX5 engine and box into it
Re: What did you do to your MX5 today ?Hello Steve ,
Thats looks like a nice car ,i assume its a kit, is it a dax or something like that ? If your need any help working on it give me a shout would love to work on it . brian ]96 na Merlot edition. sold
Re: What did you do to your MX5 today ?Cool, will give you a shout, its a Madison Roadster, bit of an experience to drive at the moment
Re: What did you do to your MX5 today ?I like the colour.
Re: What did you do to your MX5 today ?Current intake setup. Still work in progress..will be trying different setups..
![]() Lsd/gearbox oil change. Ngk spark plugs and ht leads in. Tein coilovers and big brakes fitted. ![]() Icon
RS Mk1
Re: What did you do to your MX5 today ?@davith501 might be wort trying the air filter to the right of the washer bottle next to the firewall. This is a high pressure area and seems to be one of the cooler areas to locate an air filter. Messed around with a temp sensor measuring different intake positions and this was the best.
Was considering going through firewall and getting pressurised air from there but drilling was my last option. It does make sense what you are saying..it's the corner that traps the airflow..good advice..definitely will try that next and thanks for that. Have you any thoughts on having it like this? You do not have the required permissions to view the files attached to this post. Icon
RS Mk1
Re: What did you do to your MX5 today ?I fitted a Pipercross induction kit and polished soft top. Sounds and looks great.
Re: What did you do to your MX5 today ?Fitted some mk2.5 seats to my mk1 (thanks robert) and made a nice office chair out of the old passenger seat, very comfortable, going to put a jack on the speaker wire and plug into the computer.
Ha! Love it Had to take apart my rear brake again yesterday as it was sticking, took the piston out a bit further and cleaned off the gunk + lube'd it up with brake fluid. Think I see a new piston being needed early in the new year. Also took out the air intake temp sensor as it was causing boost cut/readings flicking up and down, turned out that the connector was oxidized all back together and readings now solid.
Re: What did you do to your MX5 today ?[quote="ger"]Fitted some mk2.5 seats to my mk1 (thanks robert) and made a nice office chair out of the old passenger seat, very comfortable, going to put a jack on the speaker wire and plug into the computer.
Love the office chair... Brill. 1992 Mk1 Eunos silver
Re: What did you do to your MX5 today ?Replaced the fuel filter on my MK 2.5... Pig of a job. Those fancy connectors were very hard to get off. Got their in the end though with a bit of swearing and fiddling.
Re: What did you do to your MX5 today ?![]() Refurbished all 4 wheels . Not a great job but definitely better than what they were. 2002 MK2.5 Sunlight Silver (sold)
Who is onlineUsers browsing this forum: No registered users and 27 guests | ||
