misfire in mx5 1.8 2.5mk while travelling @60mph
Postby AdrianHealy » Sat, 25 Oct 2014 11:12 +0000
I hope some one can help. My MX5 misfires while I am travelling between 50 and 60 miles and then kicks in again. It doesn't lose speed but loses power. Te engine light flashes and then comes on solid. The solid I am told is the cat which is now ruined due to the misfires :(
I have checked plugs and leads and all replaced. Has anyone got ideas as I don't want to replace cat until sorted.
Cheers.
AdrianHealy
Re: misfire in mx5 1.8 2.5mk while travelling @60mph
Postby MX5Spares » Sat, 25 Oct 2014 11:30 +0000
Probably coils as these do give trouble.We have some perfect used ones and we have used cat also.086 8226506.Robert
Postby AdrianHealy » Sun, 26 Oct 2014 9:35 +0000
Thanks George. I will be intouch. I just need to find out which coil pack.
AdrianHealy
Postby MX5Spares » Sun, 26 Oct 2014 10:01 +0000
George ?? I have been called a lot of things over the years but never George....Both coil packs are the same so its only a case of getting 1 only, fit it,if car is still the same ,refit your old one on the other pack. 086 8226506 ,ROBERT
Postby AdrianHealy » Tue, 04 Nov 2014 12:57 +0000
Top Man Robert I will give you a call later this evening if that's ok. Sorry don't know why I put down George.
Regards,
Adrian.
AdrianHealy
Postby AdrianHealy » Tue, 02 Dec 2014 11:15 +0000
A big thank you to Robert for supply of Cat Conv and Coil pack. Robert all worked perfect and for the first time in years I have no engine light.
AdrianHealy
Postby MX5Spares » Wed, 03 Dec 2014 4:39 +0000
Great result.!!
