Re: What did you do to your MX5 today ?Great thanks Deivis
Re: What did you do to your MX5 today ?Drilled my air intake box. What a great "free" mod to do. Has made a nice tone to the exhaust.
This was the thing to do years ago with the Mk1/Mk2 Golf GTI's ! 1992 Eunos Roadster BRG V-Spec 1.6
Re: What did you do to your MX5 today ?![]() Got a new drivers seat! Sent from my iPhone using Tapatalk
Yep!! Definitely better than shelling out beer tokens for a new exhaust for the same results. 2002 MK2.5 Sunlight Silver (sold)
Re: What did you do to your MX5 today ?Pulled the cover of the green Mx yesterday morning and gave her a wash and checked all was in order. NCT this morning at 8am and passed with flying colours. NCT only till 11/9/15 as car first registered here on 10/9/08. I'll tax on April 1st for 6mths
Re: What did you do to your MX5 today ?took off my sticking rear caliper earlier and took it apart.
It was pretty mucky in there, the piston was pitted with rust and a couple of the dust covers were torn. Before : ![]() It cleaned up ok with a bit of elbow grease : ![]() ![]() Old Piston vs New Piston : ![]() Replaced all the seals + rubber bits, the new piston went in ok too. Decided to crack open the bleed nipple before I put it back on the car (and check it was all clean in there)... and it snapped in half.. GAH! ![]() Oh... and discovered I've a broken rear spring ... great ![]()
Re: What did you do to your MX5 today ?Hi Steve, I might have a spare rear spring if its any use to you? From a 92 Eunos.
Sean
Re: What did you do to your MX5 today ?Thanks for the offer Sean, unfortunately its not the original spring, its a "trim" spring (lowers the car slightly).
Similar to this : http://www.mx5parts.co.uk/trim-springs-mk1-p-353.html I'm not too confident in finding a pair... might have to switch to Jamex springs (next closest thing)
Re: What did you do to your MX5 today ?Had a hack at the bleed nipple yesterday with John M. Heat wouldn't move it, ez-out wouldn't move it, drilled it :
![]() Still couldn't get it out, kept increasing drill bit size until we got to the stage where the threads were starting to appear. ![]() Its like the threads are welded in there, none would pick out or collapse at this stage either. Its going to a professional now
Re: What did you do to your MX5 today ?That's bloody annoying.. Probably too late now but since you're so close to threads maybe tap into could've worked? Soak up with wd40 etc + heat it up + tap in..?
Icon
RS Mk1
Re: What did you do to your MX5 today ?maybe... if we'd had an M7 x 1 tap, not the most common of sizes unfortunately.
True..at that size and thread pitch wouldn't be the strongest too! You're on the right track taking it to a professional. When was the last time you where at them? That must've happen over few winters I guess.. Icon
RS Mk1
Re: What did you do to your MX5 today ?yeah, I'm suprised it was in there so tight, pretty sure I bled them this time last year.
Re: What did you do to your MX5 today ?Fitted an independent coolant temperature gauge. Easy job.
You do not have the required permissions to view the files attached to this post. 92 S Special Black
Who is onlineUsers browsing this forum: No registered users and 10 guests | ||
