Postby davith501 » Thu, 02 Apr 2015 11:46 +0000
gasha wrote:Fitted an independent coolant temperature gauge. Easy job.
Clean looking gauges. What are they?
Icon
RS
Mk1
davith501
Postby gasha » Fri, 03 Apr 2015 8:00 +0000
I got them in from China, great quality and not expensive. See below:
http://www.ebay.co.uk/itm/KUS-Water-Tem ... 2a30536bdc
92 S Special Black
94 RS Limited Montego Blue
89 Roadster Silver
gasha
Postby Real Rayzor » Fri, 03 Apr 2015 9:44 +0000
Busy Day today..
1. Engine oil changed.
2. Gear Box oil changed.
3. Rust on the boot lid sorted.
4. Tried to change the diff oil but didn't have a 23mm socket. (WTF!!) Why 23mm?
5. Cleaned and undersealed the passenger side under carriage.
6. Fitted a chassis rail to the passenger side.
Phew!! After all that I had to go play a match.
Few beers me thinks.
Real Rayzor
Postby davith501 » Sat, 04 Apr 2015 6:17 +0000
Good day in the office Ray! Keep it up!
Icon
RS
Mk1
davith501
Postby Merlot man » Sat, 04 Apr 2015 8:39 +0000
Sounds like you had a great day , keep up the good work
Brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
Postby Real Rayzor » Sat, 04 Apr 2015 10:20 +0000
Yeah it was a real big day and I loved every bit of it. Collecting some Koni coilovers for Robert next week looking forward to fitting them.
The chassis rail was easy fitting until I was under the car with the rail held up with one hand and all the bolts lined up, I reach for a nut and go to put one and it's too big...Argh!!! WTF!! :shock: No bother though I had other ones there that fitted. :D
Passenger side was easy but I'd say the drivers side will be a bit more of a challenge.. :mrgreen:
Real Rayzor
Postby Merlot man » Sat, 04 Apr 2015 10:42 +0000
Well done
For the drivers side the main thing is to consider the brake and fuel lines , remove the brackets holding them on ,even the ones past the rail and that will allow you to slip the ss rail under the lines , then fit like the passenger side refitting the brackets to the new ss rails using self tapping screws ,might be worth pre drilling for these as it makes it a lot easier while on your back under the car !
To get the brackets back on to the lines I find the a bit of greese on the plastic parts really help .
If you need a 23 mm spanner I think I have one , I'll be back at home next weekend , give a shout if your stuck
Best of luck with the work
Brian
93 na s ltd
Merlot man
Postby Real Rayzor » Sun, 05 Apr 2015 12:01 +0000
Thanks for the input Brian..i'll certainly use it. Thanks for the spanner offer.. but I'll think I'll buy a socket..
Just bought some bits on mx5parts as they have a 10% discount on this weekend.
Real Rayzor
Postby Steve » Fri, 10 Apr 2015 9:06 +0000
got a new spring in on the driver's side (as its up in the air waiting on a caliper anyway)
Got my caliper back from the machine shop... looks like its goosed.
I've ordered a new one from http://brakeparts.co.uk/ , 83stlg incl delivery !
Postby Steve » Mon, 13 Apr 2015 3:39 +0000
had another hack at the caliper (nothing to loose)
Got the remains of the old bleed screw out with a bit of cursing :
And another bleed screw in :
Put it back on the car and as expected... it leaked. Meh, at least I can put the car back on the ground now while I'm waiting for the new one.
Postby Real Rayzor » Mon, 13 Apr 2015 4:14 +0000
Hi Steve.. why not try sealing it cement glue. That 2 pack stuff that hardens like metal. If the caliper is fubar anyway, it's worth a try.
Real Rayzor
Postby Steve » Tue, 14 Apr 2015 9:22 +0000
yeah... I could with something like JB Weld... but I wouldn't be able to open it again to bleed it. Or do you mean something else?
Postby davith501 » Tue, 14 Apr 2015 11:15 +0000
Brakes, tyres, wheel nuts are all very important things on the car imo. Sometimes a diy fix just not worth it.
Icon
RS
Mk1
davith501
Postby Real Rayzor » Wed, 15 Apr 2015 10:55 +0000
Steve wrote:yeah... I could with something like JB Weld... but I wouldn't be able to open it again to bleed it. Or do you mean something else?
Yeah you would not be able to open it again. I was thinking it would tide you over till you got the new caliper. If it's leaks brake oil onto the pads they will be fubar also.
Real Rayzor
Postby Steve » Wed, 15 Apr 2015 12:00 +0000
new caliper arrived today, hope it get it on later (weather permitting)
