Postby Yolo » Tue, 15 Sep 2015 12:16 +0000
Steve try Plus Gas as a penetrating oil, its good stuff....
1992 Mk1 Eunos silver
Mk2 suspension
IL Motorsport bushes
Mk2.5 leather seats
1.8 brake upgrade
learning slowly
http://www.mazdamenders.net
Yolo
Postby 93 Mk1 » Tue, 15 Sep 2015 7:07 +0000
Yolo wrote:Steve try Plus Gas as a penetrating oil, its good stuff....
+1 for Plus Gas. Great stuff altogether.
93 Mk1
Postby Steve » Wed, 16 Sep 2015 10:46 +0000
nice one, thanks
Postby Real Rayzor » Fri, 18 Sep 2015 11:23 +0000
Got bored with my centre console so I decided to tidy it up a bit. So I got the spray cans out.
I also picked up some alloys recently. They were in bad condition TBH but I got them for nothing really. So out with the spray cans again.. No before picture but you can imagine the state of them.. bad kerb rash and completely filthy. Here's the end result.
Real Rayzor
Postby Real Rayzor » Fri, 25 Sep 2015 8:24 +0000
New (old) wheels put on.. very happy with them. So I went from 17's to 15's and I must say it's much more comfortable. Not as hard or crashy anymore.
Please excuse the bad phone pics.
Real Rayzor
New Air Vents MK2.5
Postby Eoghanb123 » Sat, 26 Sep 2015 1:47 +0000
So I decided I'd remove my eyeball vents and replace them with something a bit prettier (Well that's my opinion)
Had lots of trouble removing those little bastards, tried wedging tiny screwdrivers down the side, a j shaped piece of metal and the string method. However all failed... so I took out the pliers and ripped them out :D Safe to say I won't be using the originals! Sorry for the bad quality pictures my phone camera is cracked so the lighting is all off.
Eoghanb123
Postby Steve » Sat, 26 Sep 2015 9:58 +0000
cool, which vents are those?
Postby Steve » Sat, 26 Sep 2015 10:04 +0000
changed out the KYB shocks + sport springs for KYB AGX adjustables + Koni springs.
Postby Eoghanb123 » Sun, 27 Sep 2015 3:52 +0000
Not vents but RC car alloys! Go onto eBay and once they are 52 mm in diameter they'll fit like a glove! €6 but take a while to come. You can go all mad with red yellows purple etc but I like the chrome finish!
Eoghanb123
Postby Steve » Mon, 28 Sep 2015 2:31 +0000
Brilliant :-)
Postby elte1000 » Wed, 30 Sep 2015 3:22 +0000
Hi, last weekend I did LED lights conversion and made a short tutorial on youtube, happy with results made few small mistakes while doing it, well I,ll know better next time ;), its cheep and straight forward so anyone can do it.
here is the link if someone is interested - https://www.youtube.com/watch?v=-HRPUJlOstI
if ya got any question you more than welcome to ask .
Lukas
elte1000
Postby Steve » Thu, 01 Oct 2015 12:06 +0000
nice job! How did you wire them? To the existing loom or did you use the Canadian DRL version?
Great idea having the clock included in the video frame.
Postby elte1000 » Thu, 01 Oct 2015 3:22 +0000
Hi Steve, you just simply connect them to your existing cables on the light, there is 3 cables on the led, - amber, - white, - earth. so all you got to do is make small cut on existing cable and attach cable from led to it, everything you need is coming with the led. No idea what a Canadian DLR is :D.
LT
elte1000
Postby gasha » Sun, 11 Oct 2015 8:51 +0000
Replaced the original 5 watt headrest speakers to 150 watt Alpines.
Some improvement.
92 S Special Black
94 RS Limited Montego Blue
89 Roadster Silver
gasha
Postby gasha » Wed, 14 Oct 2015 9:10 +0000
Leaking Rad Out
Alloy Rad In, Wired Independent Coolant Temp Sensor, New Stat & Coolant Also.
92 S Special Black
89 Roadster Silver
gasha
