Not idling quite right
Postby Farasbarr » Thu, 12 Nov 2015 11:37 +0000
1992 1.6 not idling quite right. When I give it a rev it nearly stalls. I remove this bolt from a vacuum hose on the throttle body it seems to run fine. Is this hose supposed to be going somewhere? Be nice to me, I'm new to these cars. Thanks
Farasbarr
Re: Not idling quite right
Postby andrew » Wed, 18 Nov 2015 6:49 +0000
Leave the bolt in. that nipple is supposed to be capped off.
If it idles withe the bolt out, it probably just needs more air to increase the idle speed. See the black cap on the opposite side of the throttle body. lift that and you will see the idle screw. Before you start turning it, remember where it was first. I think it anti clock to increase speed.
It might also be you MAF (after filter on intake) which if reading faulty will cause similar problems.
andrew
Postby gasha » Wed, 18 Nov 2015 9:33 +0000
Here is a guide on how to set your idle:
http://www.mx5nutz.com/forum/index.php?showtopic=262209
92 S Special Black
94 RS Limited Montego Blue
89 Roadster Silver
gasha
Postby Farasbarr » Wed, 25 Nov 2015 11:50 +0000
Thanks guys. Will try that tomorrow night.
Farasbarr
Postby Farasbarr » Fri, 27 Nov 2015 11:20 +0000
Got around to servicing and playing around with the idle control, running like a dream now. Thanks
Farasbarr
