Users browsing this forum: Google [Bot] and 7 guests
 trying to do rear ledany one tryed to do rear leds? if you did it, please, share your pics
 Re: trying to do rear ledYeah ,I would like those for mine also.Did yu check MX5Nutz  forum as last year I seen lad doing it . I will search for details later
 Re: trying to do rear ledhttp://m.ebay.ie/itm/2X-60mm-HID-White- ... nav=SEARCH I read that tread too, think the lad split the lens after bakibg in the oven , wired in a set of tgese and set with glue & double sided tape Not sure of size the ones linked are only an example
 Re: trying to do rear ledIs that circular section not reflector?
 yes, it's reflector, i'am not happy at day time, and led's from ebay for 3eur sucks
 Re: trying to do rear ledyes, i know that tread on mx5nutz, i just used hot air gun, not oven
 Re: trying to do rear ledok, so second led not working at all
 Re: trying to do rear ledLed,s can only be fitted one way around.Swop over the bulbs(reverse them ) They are voltage  flow one way only not like normal bulbs which will flow either way
 Re: trying to do rear ledno no, it's just smth with led's, one ring has 12 parts with 3 led's, one ring has 4 sectors not working   second ring has bad wires  where is possibility that post man broke it whet he stuck envelope to post box  i used this set http://www.ebay.co.uk/itm/400892447616? ... EBIDX%3AIT
| Who is onlineUsers browsing this forum: Google [Bot] and 7 guests | ||
