Following an accidental welding fire, I've had to rewire a complete section of the wiring loom along the drivers seat.
I was able to repair all wires until I came across two wires with the exact same colour and size, blue with a thin red stripe.
Front#1: 12V on ignition, no markings
Front#2: No power on ignition, gold text marking
Rear#1: Leads to fuel pump, no markings
Rear#2: Leads to ???, gold text marking
So going with my best judgement, I joined Front#1>Rear#1 and Front#2>Rear#2, and tried starting it up.
Unfortunately I had been charging the battery and manged to put it back in the wrong way round After the bit of smoke at the terminals, nothing much went bang and only the main 80A fuse was blown.
So I replaced the fuse and tried again. On ignition, a yellow light above the fuel gauge came on, seems it a rear window demister (Car doesn't have one )
When Front#1>Rear#1 is disconnected, the light goes out. Either way the engine will crank strongly, but not start. I can't hear the fuel coming on on ignition, ever with a stethoscope, although I don't recall ever hearing it in the past.
Any ideas?
