oil changes - run me through it!
Postby Neelie » Tue, 20 Sep 2016 3:57 +0000
Right, so need to change all the oils. Please guys just give me a heads up that these processes are correct, and also if someone knows the tools required off the top of your head that'd be great. Im borrowing a lift but its VERY time limited so have no time for errors and wont be able to drive anywhere to collect parts :(
Engine oil, that's easy enough, for gearbox i just wanna make sure i have this right (its 6 speed box)
-open fill plug driver's side of box
-open drain plug on the bottom of box
-2L 75w90 fully synthetic into fill hole
-close her up, done
diff (its a torsen)
-same oil as above, 75w90 fully synthetic
-remove fill plug (square plug on the side)
-remove drain plug on the bottom
-1L into fill plug
-close her up, done
do i need steel washers for all the bolts?
does the box need to be filled from 2 places? i read some contradicting info....
thanks so much!
"If you don't stand for something, you'll fall for anything..." - The Wise Man
Neelie
Re: oil changes - run me through it!
Postby AndyJF » Tue, 20 Sep 2016 4:23 +0000
Before draining either the diff or gearbox open the filler first. They can seize. You don't wanna be there with an empty gearbox and no way to fill it.
Sent from my ONE A2003 using Tapatalk
AndyJF
Postby MX5Spares » Tue, 20 Sep 2016 5:10 +0000
Hi Eileen. Be careful with the 6 speed gearbox.The filer plug is not the allen key one as it holds one of the shafts in position and if removed its gearbox out job.I have diagram in shed of which one is filler.You can fill the 6 speed box through the gear lever hole but its slow .(Not same for 5 speed box)
You generally dont need washers as they are not collapseable (looks mis spelt) type just flat copper or steel but nice to have new ones if possible
I can show you on Saturday the filler plug etc or I can take pic on my phone and send to you .Let me know
Postby Neelie » Tue, 20 Sep 2016 11:10 +0000
Will be doing the work tomorrow lunch time so will Google the filler plug to be sure :) it's on the drivers side of the box right?
Neelie
Postby MX5Spares » Wed, 21 Sep 2016 7:27 +0000
Hi Eileen , yes thik its drivers side alright as 5 speed is passengers side.I will send you photo shortly
