Postby gasha » Thu, 21 Jul 2016 7:38 +0000
I have Bridgestone Potenza tyres on and will be getting them again, great in all weathers.
92 S Special Black
94 RS Limited Montego Blue
89 Roadster Silver
gasha
Postby gasha » Thu, 21 Jul 2016 7:54 +0000
Fitted a new front lip spoiler to the RS.
92 S Special Black
89 Roadster Silver
gasha
Postby mrges » Sun, 24 Jul 2016 5:20 +0000
Niiiiice.
Postby AndyJF » Sun, 31 Jul 2016 8:24 +0000
Driving around Carlow today and the clutch pedal started getting spongy to the point that the biting point was through the floor.
Checked the clutch resvior to find it low and the fluid was black.
Slave cylinder was also covered in brake fluid.
Rebuild kit on the way.
While I had my hands dirty I decided to check why the passenger window was only going down halfway. One of the clips holding the winder cables fell out and the cable with catching on the glass as it lowered. Clipped it back in and all good again.
Sent from my SM-T555 using Tapatalk
AndyJF
Postby gasha » Sun, 31 Jul 2016 9:56 +0000
I done 166 miles today in the RS and got 37.73 mpg. Pretty happy as it was a great drive.
92 S Special Black
89 Roadster Silver
gasha
Postby peteh » Thu, 04 Aug 2016 9:25 +0000
Finally got around to fitting my new momo prototipo wheel, had a nardi boss on the car so I got a wheel pcd adaptor from Bellavolante on ebay to fit the new one, here's a picture installed, took ages to do because I managed to round one of the Allen heads on the nardi wheel, managed to get it off eventually by having to drill it out, think the new wheels really fits in with the retro look I'm going for
peteh
Postby Real Rayzor » Thu, 04 Aug 2016 2:34 +0000
Looks perfect.. it does suit it well.
Real Rayzor
Postby Pops » Sun, 07 Aug 2016 8:02 +0000
Yesterday , power hosed engine , gearbox, axles . Basically power hosed / washed everything except the interior.
While I was at it I found what I think is a radar jammer, don't know if pic loaded properly , it previews upside down
Postby Pops » Tue, 09 Aug 2016 5:57 +0000
Let it be used as a playground
Postby Pops » Tue, 09 Aug 2016 5:59 +0000
Also replaced all camber bolts, 3 broke so have 5 used camber plates, nuts & bolts if anyone is stuck for one
Postby Real Rayzor » Sun, 21 Aug 2016 11:20 +0000
New clutch fitted into the mark 2.. never again will I do it on stands.. jesus what a royal PITA.
Real Rayzor
Postby Real Rayzor » Wed, 24 Aug 2016 10:35 +0000
Shiney new discs and pads fitted to the front of the mark 2.
Real Rayzor
Postby gasha » Sun, 18 Sep 2016 1:04 +0000
NCT Done Yesterday On The S Special. The tester said she was the car of the month, spotless underneath, no rust and everything tight.
For the test I put new boots on the track rod ends with new split pins 10 euro total, not bad.
92 S Special Black
89 Roadster Silver
gasha
Postby Billium94 » Sat, 29 Oct 2016 11:45 +0000
Got her first wash with the new, much wider wheels
Billium94
Postby Paschal » Mon, 31 Oct 2016 11:33 +0000
Washed and gave it a quick clean. Nice autumn photo afterwards.
Sent from my iPhone using Tapatalk Pro
