v.nice!
you keeping it on the road this winter ?
Re: What did you do to your MX5 today ?v.nice!
Re: What did you do to your MX5 today ?I'll be keeping it on the road until January and then it's back to the garage for more work!!
Re: What did you do to your MX5 today ?Fitted interior light and boot light
Re: What did you do to your MX5 today ?That's very good. You'll have to do a "how to" to let the rest of know how you did it..
Re: What did you do to your MX5 today ?These lights off eBay
https://www.ebay.co.uk/itm/201588217550 They are just about thin enough to put one above the mirror, the wiring can be tucked into the windscreen trim & down the pillar behind the trim. For me, I found a live on one of the blank switches that is only live with parking lights. A earth can be found in a suitable place. A previous owner fitted a rear fog light which was disconnected but the wiring was left in place as far as the boot hinge (with a button switch on the dash) , so I connected the lights to this . If I was to do the interior light again I would wire it differently. ... connect the light to a permanent live (fused)and have a switched earth, as in one earth through a switch and the other through the earth from the door switch,( both earths can be found at the back of the original interior light , so then the light would work as a normal interior light. You do not have the required permissions to view the files attached to this post.
Re: What did you do to your MX5 today ?Great work.. I think it's a good idea having the lights on a switch, my mk2.5 had boot lights that would come on when the boot opened which I hated because you couldn't keep the boot opened for extended periods of time for fear of killing the battery.
Re: What did you do to your MX5 today ?Still on the subject of light, I swapped the headlights for these
Old & new Will have to wait until tomorrow evening before I can get it out on the road to see the difference New one on the drivers side You do not have the required permissions to view the files attached to this post.
Re: What did you do to your MX5 today ?While the engine was running in the shed I put a wavin pipe on to get the fumes out
Sounds great at the end of the pipe You do not have the required permissions to view the files attached to this post.
Re: What did you do to your MX5 today ?More jobs done over the last few days
Replaced the fuel pump , the gearleaver boot, door speakers, and the injector seals. old & new You do not have the required permissions to view the files attached to this post.
Re: What did you do to your MX5 today ?The injector seals were pretty hard compared to the new ones, I can now hear the fuel pump running where I couldn't before, changed it a few days ago , seemed to give more power but still think it's not up to full power, will see over the next day or two if doing the seals make any difference . The new gear-lever boot might lower the road noise, still trying to setup the coilovers, a Effin nuisance they are, now on probably the fourth attempt, now removed all spring preload and set the front damper to full hard & rear to medium hard . Will see over the next few days if the changes work. Anyway, all this work gives me reasons to keep test driving it
Re: What did you do to your MX5 today ?Great work going on. Tell me,, what prompted you the change the injector seal.. we're they leaking before.
Car started to run crap , when looking for the problem one of the injectors looked damp compared to the others so I thought that the rubber seals had gone hard, they are harder than the new ones so worth replacing anyway ( every bit of rubber seems hard on this car) so I ordered a new set 6 or 8 weeks ago but only got round to fitting them now, at the same time I thought the fuel pump wasn't working properly ( couldn't really hear it working), anyway the fault turned out to be water down the plug leads in the cam cover, must have been when I power hosed the engine . Cant wait till santa brings me a timing light so I can set the timing properly, at the moment it's set by ear after changing the o ring
Re: What did you do to your MX5 today ?Fited a set of Mesiter-R coilers over the holls, the fronts were an absolute fucker to get out, the rears were a piece of cake altogether, prob took about 6-7 hours with myself and a buddie at it , a few beers probably didn't help progress. An aldi impact gun made life a whole lot easier overall. Only victim along the way was a drivers drop link but ive it bodged in for now and a replacement ordered, first impression good, will need to re raise the ride height a bit again as its not nearly clearing bumps , and pullling left now,m so need alignemnt too, will leave it a coupelf of weeks to settle first. I also need to do some under coatng as the inners have plenty of surface rust setting in
Re: What did you do to your MX5 today ?Fitted a vented headlamp cover today.
You do not have the required permissions to view the files attached to this post. 92 S Special Black
Re: What did you do to your MX5 today ?Replaced the pads and got an alignment.
Who is onlineUsers browsing this forum: No registered users and 10 guests | ||
