Re: What did you do to your MX5 today ?Got my new battery from 4 wheel online. Then I replaced the headlight bulbs with osram nightbreakers.
Re: What did you do to your MX5 today ?Stripey has been off the road since November (and due to various reasons I haven't logged on here since Christmas). About to apply for NCT, so thought I'd better get things underway......
Took off inner liners, cleaned off all dust/muck from arches and started applying Waxoyl. A few lumps of paint were peeling off the rear bumper - which did nothing for the overall appearance.... Sanded down, filler applied and 2 coats of primer Three layers of top coat - to be wet sanded and lacquered Front valance was badly scuffed - so same treatment there too. Unofrtunately none of this will affect the outcome of the NCT - but they are little jobs that do no harm to the car You do not have the required permissions to view the files attached to this post.
Re: What did you do to your MX5 today ?Oh... forgot to say above....
Car has been siting in the garage since November (and started once a week, and left to run up to temperature for a while - just to keep things moving around etc). Removed front passenger wheel to clean/Waxoyl, and spotted this! It wasn't like this when I parked it up. Both breaks (yes, in two places) are pretty fresh - nice and shiny, so I guess it must have "just happened" while sitting in the garage. Now this WILL make a difference to the NCT!!!! You do not have the required permissions to view the files attached to this post.
Re: What did you do to your MX5 today ?That's shocking (pardon the pun) I've never heard of a spring just snapping under no strain.. that's mad.
Re: What did you do to your MX5 today ?Just got back around to doing a bit on my Roadster, have been busy buying a house so that has taken up most of my time of late but we are in and settled now so I got to do a bit lately, I got a DA polisher for Christmas so I gave the car a rattle with that, used menzerna polishes (very easy to use for a novice like me) to take out any swirls and scratches, then a coat of Soft99 fusso sealant followed by a coat of Soft99 King of Gloss, highly impressed with the results from products I used,
![]() Decided to change the look of the instrument cluster, I had some wrinkle paint left over from when I did the cam cover so I took out my Jass stainless surround and painted it with the wrinkle paint ,then painted over with a matt black ![]() ![]() Refitted my instrument trim rings and the plastic cover ![]() Then on to the dials, drew these up in autocad and made them up using Hammys on mx5nutz' method ![]() Test fitting to make sure everything is working, I glued stainless steel discs to the centres of the needles, simple but effective ![]() ![]() And the finished job, gone back to a more oem look ![]() ![]() ![]()
Re: What did you do to your MX5 today ?Peteh
That car looks fantastic man ! Super cooooool ! Keep up the great work .......and the pictures ! Brian ]96 na Merlot edition. sold
Re: What did you do to your MX5 today ?2002 MK2.5 Sunlight Silver (sold)
Re: What did you do to your MX5 today ?quote="Merlot man"]Peteh
That car looks fantastic man ! Super cooooool ! Keep up the great work .......and the pictures ! Brian[/quote] quote="Real Rayzor"]:salut: Love it. Looks factory fitted. Good man[/quote] Thanks lads
Re: What did you do to your MX5 today ?Fitted Smoked Side Lights To The RS Today
You do not have the required permissions to view the files attached to this post. 92 S Special Black
Re: What did you do to your MX5 today ?Oooooh..... very nice. Suit the car really well.
Re: What did you do to your MX5 today ?Fitted a new mohari roof on Sunday. Pig of a job but somewhat rewarding, took about 8 hrs with the missues helping out. A lot more involving then i had inagined. went for black instead of the special edition blue and think it looks great. Got a baptasim of fire with the torrential rain yestday all day and all seem water tight. Bottom brackets & sacrews for the B Pillar were a total PITA. Good craic cutting off the most of old one first tho.
https://goo.gl/photos/EYeT7THQenUxQgiX8 https://goo.gl/photos/DkHzB7EQDSSH1qgE7
Re: What did you do to your MX5 today ?That top looks great, you'll have to spill the beans, where'd ya get it ? What cost? Was it on a frame ? Did it come with new seals ? Will it fit my mk1? Jealousy is a curse
Re: What did you do to your MX5 today ?The roof looks fantastic. I can only imagine what a PITA the whole thing was - but it looks well worth the effort. Well done!
Re: What did you do to your MX5 today ?hood was 295£, approx 350 euro deliveed, the recent demise of sterling helped. I had to beat them up a bit to get a good postage rate. Got for a E-bay seller called mx5-hood-shop in UK, Fit was excellet just the bottom rain seal rail didnt line up great. It didnt come with any seals but my own were perfectly reusable. Instruction provided were rubish tho.
found a good video online from maxada mania hoods, much better then most others. https://www.youtube.com/watch?v=BV-4oOvGi7U I bough new tensioner too & these were around 15E delivered from ebay, old ones were long gone.
Re: What did you do to your MX5 today ?Thanks, I've added the eBay seller to my watch list along with a mig welder.
. the welder would be for rust repair which is probably more important than what would be a cosmetic change of roof
Who is onlineUsers browsing this forum: No registered users and 17 guests | ||
