Postby Pops » Fri, 13 Oct 2017 10:50 +0000
mrges wrote:These little bubbles are along the rear rim of the roof...... just not sure if it's worth trying to sort it out now - or wait til next year (should have done it before putting the roof on the car, but I didn't! (They aren't as bad as I thought).
If they're anything like the ones on mine it's gone to dust under the paint, if you do sand them don't use heavy grit sandpaper or most likely you'll have to re paint the roof
By the way, car looks good with the roof on
Postby 93 Mk1 » Sat, 14 Oct 2017 7:16 +0000
That looks excellent. Well done !
93 Mk1
Postby Ninkynonk » Sun, 29 Oct 2017 5:33 +0000
A Busy day today.
-Changed the gearbox oil.
-Changed the diff oil.
-Cleaned up the alloys with wheel cleaner.
-Washed the car.
-Cried about needing a new soft top.
2006 mx5 mk3 nc
Ninkynonk
Postby mrges » Sun, 29 Oct 2017 10:01 +0000
A nice day to be working on the car - nice jobs done (except for crying about the soft top!).
Postby mrges » Sun, 26 Nov 2017 11:09 +0000
Purposefully opened the garage, walked in, and walked around the car for about two minutes.
Left the garage and locked it.
That's it.
And it felt good.
Postby 93 Mk1 » Mon, 27 Nov 2017 1:26 +0000
mrges wrote:Purposefully opened the garage, walked in, and walked around the car for about two minutes.
That's it.
And it felt good.
At least yours is garaged !!
Sent from my SM-T550 using Tapatalk
93 Mk1
Postby Real Rayzor » Fri, 22 Dec 2017 1:43 +0000
NCT passed with no advisories woop woop.
Real Rayzor
Postby mrges » Tue, 26 Dec 2017 12:12 +0000
Real Rayzor wrote:NCT passed with no advisories woop woop.
BIG Thumbs-Up, Ray. Well done :-)
Postby Steve » Wed, 10 Jan 2018 1:20 +0000
nice!
Postby mrges » Thu, 11 Jan 2018 10:39 +0000
Jump started the car (well, it hadn't been started for about a month) and went for a drive........ and LOVED it (and reminded me why I really enjoy having a MX5).
Then got around to getting my finger out and fitting the new front number plate. The existing plate was chipped at the corner:
Plus, I didn't like the way it looked, sitting up above the body line (I felt it took away from the smooth front end). Sooooo, new plate put on just at the bottom of the swage(?) line.
Before....
After:
Before....
After:
Sometimes it the small things that make one smile :-)
Postby Pops » Thu, 11 Jan 2018 10:48 +0000
Plate looks good, pity they couldn’t be 10/15% smaller.
Taxed mine today so now it’s officially back on the road after it’s rust repair/ re spray,hopefully get a bit of use out of it
Postby mrges » Thu, 11 Jan 2018 11:05 +0000
Now you have it taxed, clean and shiny, get out there and enjoy!
Postby Real Rayzor » Thu, 12 Apr 2018 8:43 +0000
Car has not been starting the last week.. so I went through all the posible electric tricky... symptoms were turn the key and nothing.. no dash lights, no click on from the starter. Lights, radio and fan all worked fine. Good battery.. and the starter would turn over when bridged.. I cleaned the ignition switch, neutral switch and checked every fuse and relay and earth in the car.. I the back of my mind I suspected the aftermarket alarm and immobiliser so I said fec it and ripped it all out. Fired up first time and I swear it's running better. My idle droop is definitely gone which has been driving me nuts since for ever.. happy days. Only down fall is I now have no alarm and immobiliser, I have to get that sorted
Real Rayzor
Postby mrges » Thu, 12 Apr 2018 10:08 +0000
That's great, Ray.... a success! Funnily enough, when I got Stripey the battery would drain relatively quickly if left. There was an alarm fitted (but not working), so I decided to take it all out too, and now I can leave the car for longer periods and it fires up fine and dandy.
BTW..... just so you know, I think there are dedicated web sites that sell tablets to help you with that idle droop..... 8)
Postby Real Rayzor » Mon, 16 Apr 2018 11:32 +0000
Ha... must the name of those tablet's. ..
Real Rayzor
Users browsing this forum: Bing [Bot] and 16 guests
