Intermittent no start issue (fuel pump)
Postby Bleunos » Mon, 25 Nov 2019 3:21 +0000
Hey guys, just wondering have any of you had intermittent starting issues before?
Basically the fuel pump isn't getting power sometimes, I don't think it's relays as I've already swapped the fp relay out for an admittedly second hand unit but I had the same issue.
I think it could be the cam angle sensor, I got it started last night and it was running lumpy and rich. I did a track day in it a month or 2 ago and it seems to have gotten worse sense then.
I can force the fuel pump to run by crossing fp and ground in the obd box in the engine bay. Would a cas cause a lack of power to the fuel pump? It could also be related to the immobilizer but I'd prefer if it isn't!
Sent from my ONE A2003 using Tapatalk
Bleunos
Re: Intermittent no start issue (fuel pump)
Postby Steve » Mon, 25 Nov 2019 9:42 +0000
You can borrow the CAS from my car to test, it's not moving for a few weeks.
Postby Bleunos » Tue, 26 Nov 2019 10:11 +0000
That would be fantastic, thanks Steve, I'll message you later today
Bleunos
Postby Steve » Tue, 26 Nov 2019 11:14 +0000
no problem
Postby Steve » Sun, 15 Dec 2019 6:14 +0000
How'd ya get on? Did the swop cure it?
