Not as hard as it looks to remove it
Boost chamber and pipes removed, seems to be a lot of engine oil in it
 Supercharger rattlesThe slk supercharger was making fairly serious rattling noises and very noticeable when cold, so as its declared off the road I thought I might try servicing it. Not as hard as it looks to remove it   Boost chamber and pipes removed, seems to be a lot of engine oil in it   Sent from my ELE-L09 using Tapatalk
 Re: Supercharger rattlesRemoved the snout, all looks OK  14ml of oil in the snout and it stinks something terrible  Sent from my ELE-L09 using Tapatalk
 Re: Supercharger rattlesIt did leak some more oil when it was dismantled so I'd say there was a max of 16ml in it, it's supposed to have 150ml All looks good but the circular coupler has play on one side  New coupler and oil, enough oil left over to be able to change it again if needed  All done now and no rattles thankfully Sent from my ELE-L09 using Tapatalk
 Re: Supercharger rattlesExcellent!  BTW, there is a mod to remove the internal baffle plate too if you fancy louder superchargery sounds  Sent from my Redmi Note 5 using Tapatalk
   Re: Supercharger rattlesHa ha, getting too old for any loud noises.
 Re: Supercharger rattlesI second Steve's motion  after all, it's called a supercharger, not a mediocrecharger! Sent from my ASUS_I001DE using Tapatalk
| Who is onlineUsers browsing this forum: No registered users and 19 guests | ||
