Fitting Front Fogs to face lifted MX 5 2.5
Postby Paschal » Sat, 27 Dec 2008 12:13 +0000
Ordered these fog lamps a number of weeks back but only getting around to fitting them today. Some bits missing but should have enought to go on. The fitting instructions are s*!te but we will manage. However, the fitting instructions suggest taking the positive power from the "bolt on the power line to the starter motor". Where is this bolt, what should I be looking for?
Any help would be appreciated, thanks.
Postby Stig » Sat, 27 Dec 2008 2:21 +0000
I dunno Paschal. Wish i could help!
Postby Paschal » Sat, 27 Dec 2008 5:14 +0000
No problem Ollie, I am sure someone will know how to power them. Got them fitted, took my time. Look great, all I need to do now is light them! I tried a temp supply from the battery but all I achieved was a "cooked" reley so a trip to the Motor factors is now needed.
BTW Ollie, interested in a local "run" tomorrow, might head down Laois way, bump into you, if it suits?
Postby Stig » Sat, 27 Dec 2008 5:55 +0000
sure, txt or call me - i'll pm you my no. 8)
Postby Steve » Sun, 28 Dec 2008 2:19 +0000
Be sure to put an inline fuse between the battery power line and your lights ;-)
Postby Paschal » Sun, 28 Dec 2008 9:28 +0000
Will do. Any idea where to take the power from?
Postby Steve » Tue, 30 Dec 2008 11:21 +0000
Theres a blue connector over on the airbox side of the engine bay with "always on" 12v.
Heres the wiring diagram for a '99, it should be more or less the same :
http://okmiataclub.com/spareparts/spareparts-images/1999wiring.pdf
Postby Stig » Wed, 31 Dec 2008 9:16 +0000
srigley wrote:Theres a blue connector over on the airbox side of the engine bay with "always on" 12v.
Steve, is that power source always on even after you turn off the ignition?
Reason I ask, is i'm going to fit a set of DRL's to the front of my 5 and if that power point was ignition liked it'd be real handy!
Postby Steve » Thu, 01 Jan 2009 3:15 +0000
As far as I remember it is yeah..
Postby Stig » Thu, 01 Jan 2009 1:20 +0000
Ta............and Happy new year!
