Petrol Gauge reading half full ------
Postby Kilkenny Cat » Wed, 21 Oct 2009 11:32 +0000
Hi Everyone----Well i finally got my 5 into her newly built garage but i seem to have a small problem can anyone help----????
I just noticed that the fuel gauge is registering half full while the car is standing and everything is switched off.
Just wondering is this normal or should it go back to zero when car is switched off like any other.
Any ideas boys or girls appreciated
Pat
Kilkenny Cat
Re: Petrol Gauge reading half full ------
Postby leamyj » Thu, 22 Oct 2009 6:27 +0000
As I sit here I can't remember whether the needle drops or not on switching off the ignition :shock:
You're obviously an optimist because if you were a pessimist you'd be declaring that the needle was showing the tank half-empty :wink: .
Will double check mine later, although someone else will probably have your question answered before I get back to you 8)
Postby Steve » Thu, 22 Oct 2009 8:51 +0000
It stays in place AFAIR
Postby Stig » Thu, 22 Oct 2009 9:09 +0000
srigley wrote:It stays in place AFAIR
yep!
It'll still reads, even with the battery disconnected!
Postby Kilkenny Cat » Thu, 22 Oct 2009 10:35 +0000
Hi Guys.
You learn something new everyday----- just got myself a Workshop Manual
came in post
As the english man might say---By Gum theres some stuff in there
Im still learning at my age ha ha :D I was a bit :? there
Thanks All
The Cat
Kilkenny Cat
