Hi Hazel,
Is it a constant noise or sort of like an on/off on/off rubbing etc ?
I'd go with the rebuilding kits and DIY painting myself because it's an easy job to do and the paint will last longer, best to do all four but the two rear's are usually the most known pack up before the fronts go.
Where are you based ? Maybe somebody could give your car a quick check if they are near you.
