Turbo manifold for NA6 with T25 flange
Postby rhysmate » Thu, 15 Mar 2012 4:27 +0000
Re: Turbo manifold for NA6 with T25 flange
Postby Steve » Thu, 15 Mar 2012 9:54 +0000
If you don't get one through here, I had one made by Abe in Artech, absolute gent to deal with + great quality.
http://www.artechfabrication.com/index.php
Postby mx5ideways » Thu, 15 Mar 2012 10:15 +0000
Steve wrote:If you don't get one through here, I had one made by Abe in Artech, absolute gent to deal with + great quality.
That's where I got my downpipe too Rhys, he does great work, go for it :wink:
mx5ideways
Postby rhysmate » Fri, 16 Mar 2012 9:02 +0000
if you dont mind me asking.... what kind of money did you pay lads?
Postby rhysmate » Fri, 16 Mar 2012 10:10 +0000
Postby Steve » Fri, 16 Mar 2012 12:19 +0000
Worth reading this thread, it links to a very similar (same?) manifold.
http://www.miataturbo.net/showthread.php?t=60200
ETD : http://www.protegegarage.com/600-product-600.html
I got a few quotes at the time for 2 GReddy manifold alternatives :
The ETD manifold was 449usd + 110usd shipping
Artech 325usd + 65usd shipping
Postby twail » Fri, 16 Mar 2012 12:25 +0000
Theres cheap cast ones on ebay, i have one on mine, with no issues at all!
You'll have to chop off the flange and put on a t25 one though
twail
Postby rhysmate » Fri, 16 Mar 2012 1:38 +0000
ill probably go down the cheaper route and buy ebay spec :P its gonna be a cheapish build im not looking for crazy power and im only gonna run 7-8 psi.. i can do the fabrication of the t25 flange easy enough or just buy a stainless t25 mani like the one above.. thanks lads.. looking forward to building it.. especially when theres help aroung the place ;)
Postby rhysmate » Fri, 16 Mar 2012 2:25 +0000
twail wrote:Theres cheap cast ones on ebay, i have one on mine, with no issues at all!
did you chop the flange off or make a bracket?
Postby twail » Sat, 17 Mar 2012 12:01 +0000
I chopped it and welded on a new one.
It does the job fine, and I have a t28 at .8 bar
twail
Postby rhysmate » Sat, 17 Mar 2012 6:55 +0000
twail wrote:I chopped it and welded on a new one.
Any chance you have a pic of it after you did so I can see what I must do??
