Auto electrician or someone good with wiring
Postby mx5ideways » Fri, 25 Jul 2014 9:43 +0000
Would anyone be able to help me or know someone that could? I've started doing a wire tuck in the engine bay of my new build (basically running all my engine bay wiring to inside the wings) and back out at the front for the lights, I know it's a lot of work but it really tidies up/cleans the engine bay (my brother is welding any unused holes in the bay too) Some of the wires might need to be cut or extended (would like to move the fuse box to the windscreen cowl too), Il be fitting different lights aswell front and rear so will also need these wired up, I had a friend that was helping me with this but his just after buying a house that needs a lot of work so he probably won't be able to help me for a few months, would like to get this done and the car painted before the winter so it's just a matter of bolting everything back on then, if anyone can help id be delighted just pm me a rough price, il supply all the wiring needed too. Kieran
mx5ideways
Re: Auto electrician or someone good with wiring
Postby Steve » Mon, 28 Jul 2014 1:37 +0000
Give Jeramy in http://www.autoelectricalconcepts.com/ a ring, he might be up for this.
Postby mx5ideways » Mon, 28 Jul 2014 8:50 +0000
Steve wrote:Give Jeramy in http://www.autoelectricalconcepts.com/ a ring, he might be up for this.
Thanks Steve, il give him a ring today
mx5ideways
