Auto electrician or someone good with wiringWould anyone be able to help me or know someone that could? I've started doing a wire tuck in the engine bay of my new build (basically running all my engine bay wiring to inside the wings) and back out at the front for the lights, I know it's a lot of work but it really tidies up/cleans the engine bay (my brother is welding any unused holes in the bay too) Some of the wires might need to be cut or extended (would like to move the fuse box to the windscreen cowl too), Il be fitting different lights aswell front and rear so will also need these wired up, I had a friend that was helping me with this but his just after buying a house that needs a lot of work so he probably won't be able to help me for a few months, would like to get this done and the car painted before the winter so it's just a matter of bolting everything back on then, if anyone can help id be delighted just pm me a rough price, il supply all the wiring needed too. Kieran
Re: Auto electrician or someone good with wiringGive Jeramy in http://www.autoelectricalconcepts.com/ a ring, he might be up for this.
![]() Re: Auto electrician or someone good with wiring
Thanks Steve, il give him a ring today 1990 Eunos Roadster 1.6: cusco coilovers, carbing front and rear strut braces, 1.8 brakes, performance engine and diff mounts, stage 2 cerametalic 6 puck 1.8 clutch with lightweight JUN 1.8 flywheel, 1.8 LSD, GReddy manifold, Garrett T25 turbo, ARTech down pipe, E-Manage blue ecu, Altezza injectors, FMIC. Zoom engineering center console, carbon fibre bonnet, garage vary front lip, lightweight garage hundred one hardtop, carbing 6 pt cage.
