overheating!
overheating!
Postby Rygar » Sun, 06 Apr 2014 11:29 +0000
Hi all,
Pick up a mk1 1.6 recently that needs a bit of work. My first problem encountered has been the temp gauge hitting 3/4 after roughly 10 mins driving.
Rad coolant was very rusty looking and the pipe from the cap to the overflow was completely blocked with rusty deposits.
So far I have cleared the pipe and flushed the system with no improvement.
Any advice on the next step?
Im thinking il have to go for a new rad and waterpump minimum.
Rygar
Re: overheating!
Postby shanebrk » Sun, 06 Apr 2014 12:07 +0000
Rusty water is usually a sign that air is getting into your cooling system. Have a look for leaks at the top of the rad or it could be the rad cap not sealing properly.
shanebrk
Re: overheating!
Postby Fergus » Sun, 06 Apr 2014 12:39 +0000
Sounds like there was just water and no coolant in it.
Thermo could be blocked up/bust as well, don't forget to put in a 50/50 mix of coolant/water (or whatever ratio for the coolant your using).
I'd take off the front covers and inspect the timing belt first. If it's worn or has some cracks in it then best put in a new one, water pump, thermos etc etc.
Re: overheating!
Postby Rygar » Sun, 06 Apr 2014 1:46 +0000
There was a hint of coolant in there alright. Your right timing belt will need to be done anyway once I go ripping. Anyone recommend a good supplier in the Dublin/meath area for timing belt kits, thermostats etc?
Rygar
Re: overheating!
Postby Fergus » Sun, 06 Apr 2014 2:18 +0000
Get it from Mx5Parts, shipped to your door within 3 days ;)
http://www.mx5parts.co.uk/camshaft-timi ... p-216.html
And the Water Pump.
(Mazda) http://www.mx5parts.co.uk/waterpump-gen ... p-889.html
(Aftermarket) http://www.mx5parts.co.uk/waterpump-aft ... p-245.html
May as well get a 'Crankshaft Front Oil Seal' while your at it to be safe.
http://www.mx5parts.co.uk/crankshaft-fr ... p-244.html
Other parts you may or may not need.
Thermostats.
(Mazda) http://www.mx5parts.co.uk/thermostat-ge ... p-757.html
(Aftermarket) http://www.mx5parts.co.uk/thermostat-af ... p-247.html
Cam Sensor 'O' Ring.
http://www.mx5parts.co.uk/sensor-ring-p-243.html
Thermo Housing O Ring.
http://www.mx5parts.co.uk/thermostat-ho ... -1035.html
And don't forget to put the six blobs of 'Hi-Temp Silicone Sealant' down before refitting the Cam Cover or you'll have oil everywhere ! http://www.miata.net/garage/valvecover/index.html
Re: overheating!
Postby Rygar » Sun, 06 Apr 2014 2:44 +0000
Cheers! Il get onto it
Rygar
Users browsing this forum: Google [Bot] and 2 guests
