I was gonna convert the two seats from my mk1 into gaming seats, what with the built-in speakers, but managed to sell them . They're very comfy.
Re: What did you do to your MX5 today ?I was gonna convert the two seats from my mk1 into gaming seats, what with the built-in speakers, but managed to sell them . They're very comfy.
What did you do to your MX5 today ?I was thinking the exact same thing. In fact I'm goons through my cobra gaming seat in today to see what it looks like.
Sent from my iPhone using Tapatalk ![]()
Re: What did you do to your MX5 today ?Thats some job Steve! I take it you have a heated garage?
Installed new window motor + mechanism, the old one was jammed solid.
What did you do to your MX5 today ?Far from it Steve out in the cold during the day and in front of the fire at night.
Done today : ![]() ![]() ![]() ![]() ![]() Completed underlaying. Tidied remaining wiring, lights on buzzer, central locking and starter button Going to run power supply to behind the radio for easy access in future. Discovered upper boot is split only changed it 3 years ago. And that hole above the footwell which was leaving in water. ![]() Sent from my iPhone using Tapatalk ![]()
What did you do to your MX5 today ?Update from today:
Carpet drying overnight. ![]() Carpet laying. ![]() I hope this fits. ![]() Success!!!! All the fittings are bagged and labelled ready to go in. ![]() Centre console and speedo fitted. ![]() Rear carpet fitted with new Halfords carpet clips ![]() Hmmm way too much time on my hands. ![]() Complete! ![]() Still to do replace indicator stalk struggling with remove boss. And replace rear view mirror struggling with the fitting of this also. Also need to fit seats. I threw in my gaming seat just for a look. Got me thinking. ![]() Sent from my iPhone using Tapatalk ![]()
Re: What did you do to your MX5 today ?Wow Steve, nice job, its like new! How long does it take to get the dash out?
What did you do to your MX5 today ?It's actually really easy the hardest part is the wiring especially If you've added things without considering where you're routing them.
I bagged and labelled everything so I didn't mix them up. Chuffed with it inside smells of febreeze. Lol. Has to be the most thorough valet ever. Sent from my iPhone using Tapatalk ![]()
Re: What did you do to your MX5 today ?Wow, great job, well done!
What did you do to your MX5 today ?Drove it today and wow it's super quiet. Im delighted with it. Seats were a tight fit with the underlay. All in all it's very snug.
Re: What did you do to your MX5 today ?Found what i thought was a gearbox leak. Was a CAS o ring . 4 bolts , 12mm spanner , timing light, paper clip, and some brake cleaner . 20 minutes.Oh , and a new o ring.......from a set i bought 10 years ago and used 3 times.
Well done..Sean Mc Gyver
Re: What did you do to your MX5 today ?Got front polybushes in with grease nipples but nearly froze so tracking can wait.
Re: What did you do to your MX5 today ?Couldn't start the 5, battery was almost ice + frozen to the cables/floor!?
Have it inside defrosting/trickle charging. Posted via tapatalk
Re: What did you do to your MX5 today ?started no probs tonight after the recharge , reversed out.. front right flat, doh! Forgot about the v.slow leak. Typical when its -100 out.
Re: What did you do to your MX5 today ?Batteries are really under pressure in this weather, I got stranded in the transit, battery died, it's only about a year old..roll on the spring!
