not today but last weekend.
Changed brake caliper, broke pop up light.
Next weekend,
Fix light, NCT, pass NCT, most likely break something else.
Re: What did you do to your MX5 today ?not today but last weekend.
Changed brake caliper, broke pop up light. Next weekend, Fix light, NCT, pass NCT, most likely break something else.
Re: What did you do to your MX5 today ?Not today but over the past week
Removed aircon Depowered steering rack Fitted hydro handbrake Fitted poly diff bushes Stripped interior
Is it a big job removing the air con? When I go turbo I'm going to be looking for a bigger rad also, and might want the extra room.
Re: What did you do to your MX5 today ?It was handier than i thought but i done it on a mk1 im only after buying for the track but would assume its simillar on a mk2
Re: What did you do to your MX5 today ?Whats the steering like now?
Re: What did you do to your MX5 today ?Feels very heavy when stopped or slow but feels alot better when moving fast can feel the road alot better
Re: What did you do to your MX5 today ?Removing the air con is quicker than you think, you can easily fit a intercooler in with the a/c rad too.
I have to say I think the power steering in the mk1 is the best in any car I have driven. Its one of the best parts of the car, mine see's a lot of track action too.
Re: What did you do to your MX5 today ?Ya i only removed mine because im planning on a few drift days and want to fit extra lock aswel which i have head will fuck up the seals in the rack. I had the car out a few weeks ago in a big yard seeing how it would go and ended up covering the front end of the engine bay in power steering fluid out of the resivior.
Re: What did you do to your MX5 today ?that make sense, overflowing p/s fluid is common when on track. I keep my resevoir at the min and it still boils. A bigger cooling loop could solve the problem too. Extra lock sounds good, especially for drifting.
Re: What did you do to your MX5 today ?Ya hopefully it works out now because the mx5 seems to hit the standard full lock very easy
Re: What did you do to your MX5 today ?did you loop the lines and remove the seals?
Re: What did you do to your MX5 today ?I followed this tutorial on flyingmiata. Its was alot easier than i thought it was going to be http://www.flyinmiata.com/tech/depower.php
Re: What did you do to your MX5 today ?All very well but they didn't weld up the valve on the pinion shaft so your gonna have a wee bit of play remaining.
To do it properly you must do this.......... http://www.motoiq.com/MagazineArticles/ ... -Rack.aspx The perfection of a Car's beauty is that nothing should be there for beauty's sake.
Re: What did you do to your MX5 today ?Awh it will do me for the time being see how this goes now mite do this later on
Who is onlineUsers browsing this forum: No registered users and 15 guests | ||
