Got home and her water broke.... Heater pipe burst
Users browsing this forum: No registered users and 17 guests
Re: What did you do to your MX5 today ?Rerouted the turbo oil return. Made a solid SSteel hose to stop it from kinking and blocking.
I have one bad adjuster, when the brakes need adjusting i just use the good one for both sides. They come out very easily and taking it out after adjustment wont upset the brake balance. once the wheel is locked with the adjuster, give it a 1/4 turn back and they should be just right. ger
Have you done the oil return to sump yet? Are you in on the IC piping? Wouldn't mind getting the order in soon, fergal wants one too. If we are getting 3 kits i will try and wangle a bit more off the price, see can we get it down to 100 euro or less. ger
Thanks Ger. Have a new one ordered from mx5parts!! John
Re: What did you do to your MX5 today ?Gave the car a scrub and brought it to the MOT centre on Boucher Road.
Passed ! It's a small world after all. It's a small, small world
Re: What did you do to your MX5 today ?Well done Frank, but would it pass an NCT????
(Runs for the door......)
Re: What did you do to your MX5 today ?Just your stanard oil change, replaced the passenger side rear caliper with a reconditioned one, and bled the system, brakes are now great again... oh ye weighed my tsw's.........while they were off.
18-19kgs (40lbs) a piece.. The BBS alloys she came with were 10lbs a piece...... That means i'm driving around with fook'n 4 times the original wheel weight........(ie 16 wheels) Am i making this out right...... 4 X 10 = 40lbs versus 4 X 40 = 160lbs ![]()
Re: What did you do to your MX5 today ?Found the weight of mine from last time i weighed them for someone.
They are 15kg each including the tyre. (33lbs) A quick look on Miata.net shows that Toyo T1R's seem to be pretty light @ 17 lbs with Falken 912's and others @ around 19 lbs If we say the tyres are 19 lbs then that would make the wheels 33 lbs minus the 19 which is 14 lbs not too bad for a 15x7 So not all that light either if it makes you fell any better Steve. ![]() http://www.cardomain.com/ride/3099765 "When I make a key the on position and push the button, an engine works"
Received that adjuster today.....CRIKEY They were fast, less than 2 working days Mazda take note please John
I have one bad adjuster, when the brakes need adjusting i just use the good one for both sides. They come out very easily and taking it out after adjustment wont upset the brake balance. once the wheel is locked with the adjuster, give it a 1/4 turn back and they should be just right. ger[/quote] Thanks Ger. Have a new one ordered from mx5parts!! John[/quote] Received that adjuster today.....CRIKEY They were fast, less than 2 working days Mazda take note please John[/quote] lol........Mazda Irl are ZZZZzzzzzzzzzzzzzzzzzzzzzz
Re: What did you do to your MX5 today ?This evening I checked oil/coolant Levels etc
I also checked my drain holes from ther rain rain hopper and the 4 sill drain holes. ![]()
Re: What did you do to your MX5 today ?changed the gearbox + turrent oil.. mmm.. slickness..
Re: What did you do to your MX5 today ?What did you use steve? I changged mine recently and it didn't imporve I used Castrol......
Washed and Polished her today and then sat back and watched the rain come in ![]()
Re: What did you do to your MX5 today ?Not quite what I did to the five but I did get spoiled today......
Out with the Aldi jack and in with the 3 ton jack..... ![]() ![]()
Re: What did you do to your MX5 today ?I drained redline (it was still red 6 years on!) and replaced with castrol but only because I couldn't source redline the day I was doing it.. the gearbox is changing alot easier but there seems to be some cushioning missing now..
Cleaned the K&N air filter, fixed the k&n camcover filter that melted, changed intake setup, added adjustable endlinks to the rear and added a washer to a front one.
Who is onlineUsers browsing this forum: No registered users and 17 guests | ||
