Postby franksm » Sun, 18 Apr 2010 10:57 +0000
Belfast to Dublin via the coast roads from Dundalk onwards. A nice change.
Postby anniniwa » Mon, 19 Apr 2010 9:00 +0000
Hoovered every last WHITE dog hair outta my car...wrecked!!! but she sure did enjoy the spins so was worth it! :D
Postby sidewaysreilly » Tue, 20 Apr 2010 9:26 +0000
dye the mutt black and you wont notice :D :D :D :D
Postby Steve » Tue, 27 Apr 2010 12:23 +0000
Am trying to tune the car at the moment so need to see if I'm running rich/lean easily, so wired in a LED Panel to read the volts from the (WB)O2 sensor :
Got halfway through changing the clutch lines + slave cylinder before an "almost" rounded off bolt (slave lower bolt) + rain drove me indoors.
New clutch line + adaptor on the slave.
Postby Steve » Wed, 28 Apr 2010 1:03 +0000
That lower bolt was a nightmare to get out.. t'was in way too tight. Got it out eventually with big help from Jay (thanks again Jay!), put in the new one + new line + bled. Feels fab so far, will get it out for a spin tomorrow.
Postby barney » Fri, 30 Apr 2010 9:23 +0000
changed oil and filter. used castrol magnatec. also changed diff oil. made quite a difference. will do gearbox at a later date. stereo not keeping settings as when i remove keyfob with immobiliser attached all power seems to be gone. interior lights won't even work. couldn't find a constant live.
Postby Steve » Fri, 30 Apr 2010 11:35 +0000
Halfway through fitting a new turbo manifold gasket (had a burruutal leak after refitting). Snapped a bolt in the turbo.. so off to the tool shop in the morning .. doh!
Postby franksm » Sat, 01 May 2010 12:19 +0000
ar$e biscuits
Postby mx5ideways » Sun, 02 May 2010 2:38 +0000
fitted 4 new toyo T1Rs to the car yesterday,brilliant tyre,would definatly recommend them for the mx5
mx5ideways
Postby aquarian5 » Mon, 03 May 2010 1:16 +0000
Sideways, where did you source the Toyos and how much....??
Cheers John.
Postby mx5ideways » Mon, 03 May 2010 1:35 +0000
aquarian5 wrote:Sideways, where did you source the Toyos and how much....??
Cheers John.
i got them from my local tyre place in newcastle west,they dont usually deal with toyos but did me a favor as i heard they were great,got them for €250 fitted and balanced 195/50/15s
mx5ideways
Postby Steve » Mon, 03 May 2010 9:36 +0000
Drilled out snapped downpipe bolt (gah!).
Then turbo to manifold bolt rounded off (12point ring) while tightening.. its stuck
on till I get a 6 point ring spanner now.
Off to the tool shop again..
Postby mx5ash » Wed, 05 May 2010 10:13 +0000
Changed out the trans fluid today (the cowboy way!!!) and my god what a difference. Car had been slipping during take off and changes were a little jerky. It now pulls away cleanly ever time and changes are much smoother. Had a really good blast round country lanes in it this evening and it felt the best its been for a long time.
Also gave it a mammoth clean in prep for this weekend (I would have been ashamed of it the way it was)
All is looking good now. 8)
Postby Steve » Thu, 06 May 2010 1:30 +0000
Got the nut out (YAY!) eventually!
Postby Medic5 » Fri, 07 May 2010 12:03 +0000
Fitted new Chrome fuel lid and chrome ashtray cover, washed car will polish tomorrow! Tried to fit chrome rear view mirror cover, but it's only for glass mounted mirrors.......so now it's for sale :roll:
