Re: What did you do to your MX5 today ?Hope you remembered to put the roof up firtst Stig
Re: What did you do to your MX5 today ?Hey Ferg, how many penalty points did you accumulate on your way home from Frank's today what with your entry to the dark side?
Best of luck with it BTW John
Re: What did you do to your MX5 today ?well went to put in petrol ....cap would not open so tried to urge it with locking key and bent my key....a great day all round!!! any ideas why my petrol cap not opening lads
hilly
Re: What did you do to your MX5 today ?Hi Hilly
Either it is jammed (the hinge needs a bit of oil) or else the cable is broken or has popped off the lever in the console, or the latch in the filler cap. Anyway, you can manually pop open the filler cap from within the boot - if you look up into the innards of the workings of the filler cap, you'll see a little finger-latch at the 12 O'clock position just above the cable (like a bicycle brake cable). Just pull it towards you and the filler cap should open. If you get it open, give everything a good douse of WD40 Frank It's a small world after all. It's a small, small world
Re: What did you do to your MX5 today ?Thanks Frank your a star
Is that a dog you have etched on the side of your car????
Re: What did you do to your MX5 today ?Got the alignment changed on the car today by the lads in Rathcoole. Since I mainly do motorway miles now.
old settings Front, Caster max, camber -2.25deg toe 1.5deg out overall Rear Camber -4deg 1deg toe in overall New settings Front Cater 4deg camber -1.5deg toe 0 Rear Camber -2deg 0toe Also got new shoes ![]()
Re: What did you do to your MX5 today ?Finally caved and put in NGK ignition leads ..... yes Frank, yes they are fab
Re: What did you do to your MX5 today ?Changed all my vacuum hoses out for silicon - couldn't get them in black, so they are mildly-blinged-blue. BTW the leads are NGK blues, not that you can tell
![]() It's a small world after all. It's a small, small world
Re: What did you do to your MX5 today ?Fitted a new roof with the help of ever useful Dave, Pics to follow
Re: What did you do to your MX5 today ?Installed the Bipes unit to go with the Greddy turbo along with the boost gauge and EGT gauge (who knows?).
Has made a huge difference bosst is much more controlled. Car sounds GREAT and is certainly a whole lot quicker. It's runiing on a little over 4 Bar or 6 PSI. I like Thanks again to Frank and Ger for all the advice and help.
Re: What did you do to your MX5 today ?my radiator went today seem to be having a run of bad luck anyway was quoted by local mazda 200 euro plus vat for rad before fitting ordered from mx5 parts incl delivery for under 100 ( are we getting ripped off or what )
Hilly
Is that the sound of a penny dropping??? John
Cool! Did you tighten the wastegate? Steve P.S. 0.4 bar
Who is onlineUsers browsing this forum: No registered users and 17 guests | ||
