Now to mount dummy Intercooler and work out how much pipe i need.
Users browsing this forum: No registered users and 16 guests
Re: What did you do to your MX5 today ?Did leakage test.. 20% leakage all round so all good
Re: What did you do to your MX5 today ?Paid the VRT and got the new plates put on!!! Tax and NCT next...bummer!
Re: What did you do to your MX5 today ?drain pipes cleared.
result: I am dirty, but pipes are clear Btw i am really surprised, how poeple have trouble finding them...
Re: What did you do to your MX5 today ?While the weather's reasonably good, you might consider checking the rain rail for dirt and other gunk.. better to do it now than in the winter
Re: What did you do to your MX5 today ?rain rail? where is it, how does it look, becouse i have some trouoble with water today...
Re: What did you do to your MX5 today ?Today, as it did nothing only piss rain I spent some time in my home away from home (the garage
I've been bitten by the bug and I get a strange sense of satisfaction from cleaning and pimping my bay......sad but true Anyways, the air inlet manifold was my target today. ![]() I want to spray it up like my cam cover so it needed to be totalled wired brushed down and then machine brushed as well as the dremel going at it to get into those nooks and crannies. Came up well so far - ![]() I cleaned and prepped the ring clip too and sprayed it black - here's it drying - ![]() ![]()
Re: What did you do to your MX5 today ?Busy boy eh! Something I'll be taking a look at doing, shortly.
I got the numberplate plinth on E-bay from Autolink, fitted it and the front looks a lot better for it. Tom
Re: What did you do to your MX5 today ?Got the chrome pack from Mx5Parts, chrome surround for haz/pop up lites switch, chrome vent balls, fitted all with no problems. Am just left with 4 chrome covers for the rev counter, spedo, fuel and temp gauges. Tried to get the centre console off, but with no luck........ any ideas???
Re: What did you do to your MX5 today ?The cowling can be removed by grabbing on both sides and pulling forward with EVEN force..be careful, I broke two of the three fixings when taking mine off. The instrument panel is easy enough to remove, it's screwed in AFAIR.
Re: What did you do to your MX5 today ?Thanks John, I unscrewed the area around the steering wheel, then undid the 2 screws holding the cowel in place, but could not get it out.
Re: What did you do to your MX5 today ?Pull it straight towards you PJ, but try do it with one sharp pull
Sounds perverted now doesn't it..... You'll know your done, when it comes off!!!!!!! ![]()
Re: What did you do to your MX5 today ?Think I'll wait 'til the next run, that way I can blame someone else when it gets yanked out and broken
Re: What did you do to your MX5 today ?You gonna let someone pull it off in Tullamore or are you gonna wait and have it pulled off in Lough Key?
Re: What did you do to your MX5 today ?Well if you want something pulled off then the next run is the best place, especially if John L is around. He's really good a pulling stuff off, like windscreen washer jets, and Ollie can testify to this.
Good luck with the rest of your fit-out. Tom
Who is onlineUsers browsing this forum: No registered users and 16 guests | ||
