Car won't start - think I need a coil pack?
Postby jennytree » Sun, 18 Oct 2009 7:02 +0000
Hi All!
Be kind to the n00b :oops:
My car (1.6, '99) died last week as I was going for a drive. There were no odd noises, bangs or stutters. It'll turn over with no problems, but just won't start. I had a mechanic look at it and he is saying that I need to get a coil pack. Mazda Ireland are quoting €500+ for it ( :shock: ) so obviously I'm on the look out for a cheaper one.
I see there's one on mx5parts for about £150. I just don't want to fork out that much just incase that it's not whats causing the problem. I did a bit of googling and it does appear that these have been known to go in the mk2's.
Do I have any other options here? It appears that I have to get a specific one to the model/engine size of my car, does this sound right?
Any help is appreciated!
jennytree
Re: Car won't start - think I need a coil pack?
Postby leamyj » Sun, 18 Oct 2009 8:15 +0000
Hi Jenny, if you let the forum know where you're located then maybe someone nearby will be able to assist in "loaning" you a pack for the purpose of problem elimination. Have a look through the "for sale" thread, there may be some contacts there for guys who are breaking 5's, they may have what you're looking for.There are also a number of salvage options on the net, sniffydog.co.uk comes to mind and traynors up north have been used by members in the past too.
Good luck
Postby Stig » Sun, 18 Oct 2009 8:48 +0000
Hi Jenny,
Welcome to the forum, the coilpack apparently is somethnig that does go pop it seems and is very pricey, but not in the €500 region.
Heres one that may sort you -
http://www.autolinkmx5.com/coil-pack-mx ... 1070-p.asp
price in sterling, and then +vat and P&P
HTH's
O
Postby Steve » Sun, 18 Oct 2009 11:17 +0000
That one isn't for a '99 tho Ollie ;-) Its a mk1 coil.
The one you need is a little more than 150sltg (thats the one for pre 99 cars, the mk1).
This is the one for a mk2 :
http://www.mx5parts.co.uk/product_info. ... cts_id/779
Yes, common problem. Easy to replace the coil (just disconnect the battery first).
Postby jennytree » Sun, 18 Oct 2009 11:20 +0000
Thanks for the help and links!
I'm based in Dublin but I will travel to get it at this stage as I just want to get up and running again!
I'll leave it till Wednesday or so, then order from MX5 parts.
jennytree
Postby sidewaysreilly » Sun, 18 Oct 2009 11:37 +0000
send me a pm with contact details, we have proper spark testers which load up the coil and will verify if it is faulty.
Postby jennytree » Tue, 27 Oct 2009 6:10 +0000
Sorry for not getting back to you Sideways, I'm still on the hunt! How exactly can you test if the coil pack is the problem?
I'm still hoping to get a cheaper one than the €300 one I have currently find. I just don't want to invest that much if it's not whats causing the problem!
jennytree
Postby Stig » Wed, 28 Oct 2009 11:00 +0000
srigley wrote:That one isn't for a '99 tho Ollie ;-) Its a mk1 coil.
oppps, apols. :? :cyclops:
Postby Steve » Thu, 29 Oct 2009 12:58 +0000
Jennytree, just a thought, have you changed your ignition cables recently?
Postby jennytree » Thu, 29 Oct 2009 1:07 +0000
I haven't really done anything with the car since I got it in February :oops: Could the cables cause the same issue?
jennytree
Postby Steve » Thu, 29 Oct 2009 1:26 +0000
they could have contributed to carboning up your coil.
I'd take sidewaysreilly up on his offer.
Postby jennytree » Tue, 03 Nov 2009 3:58 +0000
another one for ye all!
Is this something I could change myself? What precautions would I have to take before going for it?
jennytree
Postby Steve » Tue, 03 Nov 2009 4:46 +0000
yes, its 3 bolts. Disconnect the battery first.
Postby sidewaysreilly » Thu, 05 Nov 2009 11:53 +0000
Postby jennytree » Tue, 10 Nov 2009 2:41 +0000
Thanks a mill Sideways. Also, sorry for not getting back to you. I found a coil pack and had a mechanic put it in this morning but the car still isn't starting :shock:
He now thinks it's the immobiliser/electrics, and is getting another friend of his to take a look at it in the morning.
Very frustrating :x
jennytree
