Need door fixed
Need door fixed
Postby Middy » Mon, 22 Mar 2010 6:35 +0000
Hi,
My passenger door lock has broken so I cant get the door open. The key turns but wont come out unless you lock the door again.
Similar happened on the drivers side few years back and a guy called Phil McCarthy fixed both the door and the regulator on the window. The contact number for Phil no longer works. I would appreciate it if someone knows how to contact Phil & could send me his number or the job is up for grabs if anybody else does this work? (Last resort I'll order the parts and get someone to try but I'd rather somebody who has fixed this before take a look)
Much appreciated
Marie
Middy
Re: Need door fixed
Postby Steve » Mon, 22 Mar 2010 11:33 +0000
Hi Marie,
Welcome to the forum, where in the country are you? If near Galway let me know and I'll have a look (sounds like the rod has come off the lock inside the door).
Re: Need door fixed
Postby Middy » Tue, 23 Mar 2010 2:45 +0000
Thanks Steve, unfortunately I am in Dublin :( Thanks again though. I might get my brother to take a look & we might post some questions again. Cheers!!
Middy
Re: Need door fixed
Postby leamyj » Tue, 23 Mar 2010 6:42 +0000
Middy, there's a tech day in Blanchardstown next Saturday, would be happy to have a look for you. Let us know if you can drop over.
Re: Need door fixed
Postby Middy » Tue, 23 Mar 2010 6:53 +0000
That would be great - thanks a mil. I should have mentioned it's a Jap import in case that makes a difference, if not please send on the details!!
Middy
Re: Need door fixed
Postby leamyj » Tue, 23 Mar 2010 7:28 +0000
The venue is @ Unit 240, Blanchardstown Corporate Park 2, Ballycoolin, Dublin 1, not very far from the Blanchardstown centre. You can ring me on 087/2656053 if you get anywhere near, say between 12 and 12:30?? there is a map around somewhere, I'll try locate it and post it here.
Re: Need door fixed
Postby leamyj » Tue, 23 Mar 2010 7:33 +0000
Re: Need door fixed
Postby Middy » Tue, 23 Mar 2010 8:26 +0000
thanks a lot for your help. I should find it easily. I'll head out there for 12ish. Much appreciated
Middy
