Postby s-mac » Thu, 18 Aug 2011 10:29 +0000
Fitted new radiator today at last, been almost a month now since I drove it!
Barney, that sounded like a good run, you for the Pat Lough show this Sunday?
s-mac
Postby mc555 » Fri, 19 Aug 2011 2:32 +0000
A bit of spannering and some driving! :D
mc555
Postby leamyj » Fri, 19 Aug 2011 2:40 +0000
Changed wheels and tyres over for a track day in Kirkistown tomorrow...no point in destroying the new ones :mrgreen: :mrgreen: !!
Should have some footage by Sunday/Monday...assuming I don't completely make a tit of myself!!!
Postby barney » Sat, 20 Aug 2011 5:44 +0000
Smac, i'll be in Ardara tomorrow for the Pat Lough show. On nightshift tonight and tomorrow night so may head home when the run starts at 3pm. I'll see you there
Postby leamyj » Sat, 20 Aug 2011 11:22 +0000
Sorry..no footage of Kirkistown..battery on camera decided to commit suicide!!! Gave the car a good old thrashing around the circuit, and it behaved impeccably!!! Unfortunately I was the least powered car there, in among Porsches, Lotus's, subarus, and a few bmw's ..but I think I had the most fun!!!! :mrgreen:
Postby cseaj » Mon, 22 Aug 2011 1:58 +0000
fitted new battery. upgraded head unit to pioneer avh-p6600dvd
and fitted 2 new/old sony 6x9 speakers in to doors . worked to be
easy enough to do well pleased.
chris (cseaj)
cseaj
Postby cseaj » Wed, 24 Aug 2011 6:33 +0000
changed the diff oil .i thought the oil would be more burned /black like engine oil but came out clean
an other job ticked off the list
chris (cseaj)
cseaj
Postby VDubbin » Thu, 25 Aug 2011 4:22 +0000
Repaired a few gaps in the hood with Sugru. Also tested the last of a can of Halford's Matt Black, with varying results…
VDubbin
Postby cseaj » Fri, 26 Aug 2011 11:15 +0000
today ive changed the anti roll bar bushes back and front
and the drop link bushes back and front as i had a spare set here so cleaned the metal
droplinks and gave them a coat of matt black to freshen them up. so 1.5 hrs and had the 4
corners done
cheers chris (cseaj)
cseaj
Postby cseaj » Thu, 01 Sep 2011 9:53 +0000
today ive bonded bolted and replaced the rubber seal around
the glass screen on the hardtop. (had the screen taken out for
respray) turned out ok will ad some pictures later
chris
cseaj
Postby gannons_gunns » Sat, 03 Sep 2011 5:58 +0000
bunged it over the pit in work and got under and had a good old check over
and checked to see what kind of diff is fitted torsen me thinks :twisted:
and washed all the crap out of the rad
gannons_gunns
Postby Steve » Tue, 06 Sep 2011 1:01 +0000
Cleaned out windscreen washer jets (air line wouldn't clear them), packed with muck.
Took off the steering wheel and moved it one spline to the left to straighten it.
Stripped down the front of the engine and reset cambelt tensioner.. but can't remember if I retighened it.. gah! Might get away with just removing cam cover and top cover off the front to check it.
Postby twisty » Thu, 08 Sep 2011 7:41 +0000
Today i replaced a worn rear wheel bearing , i also stripped back some of the under seal and paint around the welds in the rear arches , reprimed , painted and resealed to keep any rust away and get ready for the winter
the old and very sorry looking bearing
and the new one ready to be pressed in
twisty
Postby peteh » Fri, 09 Sep 2011 3:29 +0000
Fitted the RS Style Hazard/Pop Up switches I got from a guy on MX5 Nutz, nicely retro :D
peteh
Postby atank » Tue, 13 Sep 2011 6:17 +0000
Added My Own Carinavore Teeth! Just until I get fresh paint, then I will remove them.
atank
Users browsing this forum: No registered users and 26 guests
