Performance manifold, 1.8 and 1.6, lightweight flywheel
Postby mx5ideways » Fri, 18 Nov 2011 7:35 +0000
Im going to go down a different route for the track car I hope to build, I'm going to use a different engine than the 1.8s I have so I'm going to sell the few bits I have to fund it some bit, I have a performance manifold that came off a 1.8 rs and the performance manifold that came off my 1.6 (which made a big difference to the car but as I'm going with a turbo I won't need it) its still heat wrapped too but will need a small bit of welding (your man fitting the turbo cut the end of it off where it connects to the decat) you could use the end of your old manifold to weld onto it if interested, I also have a lightweight flywheel from the rs, a few body panels, alloys and the 1.8 engines and gearboxes
1.8 manifold: €200
1.6 manifold: €240
Lightweight flywheel: €150
1.8 engines: €250 each or €400 for both
Gearboxes: €100 each
Il take best offers on everything but want to try and get as close to asking price if possibly, il get pics up soon too
mx5ideways
Re: Performance manifold, 1.8 and 1.6, lightweight flywheel
Postby sidewaysreilly » Sat, 19 Nov 2011 3:39 +0000
what weight is the flywheel
Last edited by sidewaysreilly on Mon, 21 Nov 2011 1:30 +0000, edited 1 time in total.
Postby andrew » Sun, 20 Nov 2011 9:59 +0000
what different route, I'm going to go supercharged with a TR Lane kit.
I'd like that 1.6 mani, but don't know if it will fit under a charger
andrew
Postby mx5ideways » Mon, 21 Nov 2011 10:33 +0000
I'm going to try and go rotary power, your man doing my mk1 turbo has some nice ideas for building it, I know it might not be as reliable but I won't have it out on a track that many times in the year anyway, plus it's a really light engine
mx5ideways
Postby leamyj » Wed, 23 Nov 2011 7:41 +0000
Rotary in an mx5...will that be a first in this country?? Would really like to see that in action!!
Postby andrew » Wed, 23 Nov 2011 3:58 +0000
fair play to you. Some sound off the 13B. Do it.
andrew
Postby mx5ideways » Thu, 24 Nov 2011 12:23 +0000
leamyj wrote:Rotary in an mx5...will that be a first in this country?? Would really like to see that in action!!
I think so plus he wants to be the first person to build a peripheral port rx8 engine into a track car here and he likes the mx5s because their so light and easy to make even lighter plus handle great, he said with the peripheral port it should rev to 14000 rpm and sound unreal 8) , I'm looking at an rx8 next week that I fella is buying to fit an sr20 into which will hopefully leave me with a nice rx8 engine and 6 speed gearbox, il hopefully be able to sell a few of the other bits though cause I don't think its going to be very cheap :roll:
mx5ideways
Postby Steve » Thu, 24 Nov 2011 7:43 +0000
This guy is doing the opposite (MX5 engine into an RX8) :-)
Postby mx5ideways » Tue, 06 Dec 2011 8:35 +0000
Here's some pics of the manifolds
mx5ideways
Postby mx5ideways » Tue, 06 Dec 2011 8:39 +0000
sidewaysreilly wrote:what weight is the flywheel
I'm not sure, its at the home place so I can't weigh it but its the lightweight one that comes in an rs, that's what it came off anyway
mx5ideways
Postby mx5ideways » Tue, 06 Dec 2011 8:42 +0000
Any offers on any of these bits :?: we picked up an rx8 sunday and my mk1 shell was collected yesterday so I'm defiantly going ahead with the conversion
mx5ideways
Postby indie » Sat, 10 Dec 2011 6:00 +0000
looking for a bit more info on the engines, are they running and how much of the engine is there, ie intakes manifolds ect ect.
would you have pics of them?
thanks
indie
Postby mx5ideways » Tue, 13 Dec 2011 3:13 +0000
indie wrote:looking for a bit more info on the engines, are they running and how much of the engine is there, ie intakes manifolds ect ect.
thanks
Both engines were running, one was perfect and the other was a little tapaty, everything is on both engines, inlet/manifold exhaust, etc. il take pics when I'm home again, probably next weekend
mx5ideways
Postby Conorbg93 » Sat, 31 Dec 2011 1:12 +0000
Do you still have the flywheel, I'm interested in this. Thanks
Conorbg93
Postby mx5ideways » Sun, 01 Jan 2012 6:11 +0000
Conorbg93 wrote:Do you still have the flywheel, I'm interested in this. Thanks
Ya I still have it, give me a call if you want, 0874151903 , kieran
mx5ideways
