Postby mx5ash » Sat, 10 Dec 2011 12:19 +0000
Just one of them things, only rear lights are allowed to be red. Tape em up for the next test and it will be fine or remove them for test. Co2 could be a simple service and get engine good and hot before test. What were other test results? Lamda and hc?
Postby tiggerl82 » Sat, 10 Dec 2011 12:38 +0000
mx5ash wrote:Just one of them things, only rear lights are allowed to be red. Tape em up for the next test and it will be fine or remove them for test. Co2 could be a simple service and get engine good and hot before test. What were other test results? Lamda and hc?
The car had just an oil pump change.... So new oil, new filters, etc.
Every other data is within limits.
The Co at 850 rpm is 0.05. the fail is above 0.50...
HC is 37ppm, above 0 ppm fail, but at the result it says N/A... (dont understand that) at 850 rpm
at 2800rpm: HC is 22ppm, fail above 200 ppm
at 2800rpm: lambda is 0.99, limit is between 0.97-1.03
so everything else is fine... the engine was warm, but had to wait 30 min before they took it in. He checked the emission at least for 10 minutes after that, so the engine had time to warm up again...
Mazda Eunos Roadster B2 Limited
tiggerl82
Postby mx5ash » Sat, 10 Dec 2011 8:05 +0000
The na means that don't test it, your car an import? If so they dont have high idle test data to compare it to.
Did you change spark plugs and air filter? Check for vacuum leaks and check exhaust for leaks. Could also try a bottle of dipatiane (sp?) in tank. It's not a very high result and all other data seems fine so not a big issue I'd say.
Postby eyore » Sat, 10 Dec 2011 7:35 +0000
I now have properly working headlights that actually go up and down as they should. Poor long suffering hubby removed left motor and dismantled it and greased up everything. Hurrah, now need to save a few euros to get the bonnet resprayed :roll:
eyore
Postby peteh » Wed, 14 Dec 2011 5:20 +0000
Fitted a set of stainless steel electric window toggle switches I got from a guy over on nutz
Also fitted a zoom starter button got from rev9, very james bond!!
peteh
Postby eyore » Wed, 14 Dec 2011 6:07 +0000
As a matter of interest, when did the emissions regs change? What I am trying to ask is, older cars face less rigerous standards, what year do the older cars go up to before the stricter emissions standards come into force?
eyore
Postby gunners5 » Wed, 04 Jan 2012 10:27 +0000
I have waited years to fit these beauties, solid metal and gorgeous.
gunners5
Postby Steve » Thu, 05 Jan 2012 12:03 +0000
'93 I think.
Postby indie » Fri, 06 Jan 2012 10:40 +0000
after fitting the coilovers on monday i brought the car over to a guy just off Amiens st to get the alignment done.
its very rare that somebody brings you under your own car and takes the time to explain what there doing and lets you inspect your own car while its in the air. had a good look under it with a torch looking for the usual nct type fail stuff, cv boots, steering rack gaitors ect and am pretty happy with it.
indie
Postby fobbzy » Fri, 06 Jan 2012 11:11 +0000
Well I hoovered my roof and cleaned my drains........ :roll: :roll: :roll:
Yeh I know it sounds odd but thats what I did...... hoovered the nooks and nannies on the old mohair and then stuffed the old trumpet cleaner down the drain channels........ :lol: :lol: :lol: .... oh and then fed the leather seats with some feeder so they are out there in the drive way just chomping away :wink: :wink: :wink:
No listen I can hear them honest........... :shock: :shock: :shock:
Hope they don'tset the alarm off with their noisy burps n farts the neighbour hood watch will be round...... :twisted: :twisted:
fobbzy
Postby Steve » Sat, 07 Jan 2012 10:26 +0000
a wash (first since Sept :? ) and hardtop'd
Postby Reesy » Sun, 08 Jan 2012 11:38 +0000
...it's more what my MX5 did to me...
Long time no post. Hello all.
Went for my NCT this am (yes, 9:25am Sunday, I know!) having had the car serviced a month ago & having checked it myself yesterday.
Test aborted due to leaking coolant hose (this one http://www.mx5parts.co.uk/upper-bottom-hose-silicone-mazda-p-561.html) spraying onto exhaust manifold. Am currently mulling whether to replace all the hoses or just this one + one heater hose which was on my list to change anyway.
Got a refund of the test fee cos the fella (very decent chap) had not done any of the tests before spotting it. Car out of action... and it's only 10:40am!
Happy new year all
Simon
Reesy
Postby Oregato » Sun, 08 Jan 2012 4:09 +0000
Got a new headunit for it :) Will be fitting later :D
Oregato
Postby Steve » Sun, 08 Jan 2012 10:00 +0000
Reesy wrote:...it's more what my MX5 did to me...
Happy new year all
Simon
Hi Simon,
I replaced all the hoses on my car with their kit last year, there are just two that are tricky, the two heater hoses behind the head. Quick tip, cut the old hoses lengthways (carefully, the metal pipes are very soft) with a stanley blade to remove them. The new ones needed a little bit trimmed off the ends too so prob best to measure them up against the old ones before fitting. One last thing, rather than try and replace the original spring type clamps behind the head, I replaced with the screw on type.
HTH
Postby indie » Mon, 09 Jan 2012 11:33 +0000
Today i fitted my induction kit, mostly for its acoustics which are beefy and rather nice. removed the charcoal canister with the intention of re-locating the washer bottle to its side to free up space near the manifold. also sprayed the final coats of laquer on the diy skirts.
and finally took up the slack on the throttle cable, made quite a differance too
indie
Users browsing this forum: No registered users and 27 guests
