Trouble with my Roadster
Postby tiggerl82 » Wed, 10 Oct 2012 10:17 +0000
I have trouble with my MX5 as well. Shit week for me... Both cars are crazy... Its a 97 jap import 1.8
When i start the engine in the morning, it drops the rev. The engine almost stops, but never stops. It does for a few minutes. Every time drops the rev down u can hear a clicking sound as well. (It sounds like a relay). Anyone had this before? Plugs were changed 2weeks ago. Sometimes from low rev when i accelerate it halts for a second. This happens as well when the engine is warm...
Any ideas? Thanks very much!
Mazda Eunos Roadster B2 Limited
tiggerl82
Re: Trouble with my Roadster
Postby Steve » Thu, 11 Oct 2012 1:05 +0000
Try starting it from cold in the dark too and see if your coil pack is arcing, you should see sparks near it.
Or ... is it an exhaust manifold leak? Is it ticking "in time" to the engine?
If it is, it might explain why the revs are dropping too (running too rich due to incorrect O2 sensor readings).
Postby rhysmate » Thu, 11 Oct 2012 8:03 +0000
could it just be the idle setting?
rhysmate
Postby tiggerl82 » Thu, 11 Oct 2012 8:12 +0000
It came up maybe 2 weeks ago. We changed the plugs, and it didnt do it for a while, and started yesterday again. It very hard to drive now, couse the engine always halts... Its in daily use, so i need to find a solution sos... i try to bring to my mechanic today. Thanks very much for the ideas!
tiggerl82
Postby tiggerl82 » Thu, 11 Oct 2012 8:38 +0000
tiggerl82
Postby tiggerl82 » Thu, 11 Oct 2012 8:40 +0000
tiggerl82
Postby tiggerl82 » Thu, 11 Oct 2012 9:09 +0000
http://youtu.be/083TZUqj31E
This was 2 weeks ago on cold start...
tiggerl82
Postby pjmazda » Thu, 11 Oct 2012 11:25 +0000
Can you follow exactly were the click is coming from? Look up over the pedals at the relays. I believe there is a fuel pump one here ... am think this might be faulty and maybe switching out fuel pump momentarily and hence causing engine to die a little ...
pjmazda
Postby tiggerl82 » Thu, 11 Oct 2012 11:44 +0000
Steve was right with the leads. Great little fireworks was under the bonnet. One of the cables totally burnt... My mechanic found a spare one, and the car is runnin now. Im looking for leads, but nobody has it, needs to be ordered everywhere...
tiggerl82
Postby rhysmate » Thu, 11 Oct 2012 11:56 +0000
i might have a set of leads or autocheck would id say!! hes in Dublin too
rhysmate
Postby tiggerl82 » Thu, 11 Oct 2012 12:35 +0000
Thanks everybody for the help, i sorted a new set by the afternoon! It went completly wrong this morning. I almost could't make it till my mechanic...
Still dont know what was the clicking sound... It came from under the dashboard... Maybe when the sparks gone, the AC pump turned off itself?
tiggerl82
