Heater pipe to connect fan to heater matrix.
Postby sidewaysreilly » Sat, 01 Dec 2012 6:15 +0000
Deleted the aircon a few years back but finally got diggin under the dash to see why the fecker is sooo bloody cold.
Anyways, found the joint between aircon unit and heater matrix to be leaking out most of the cold blown air into cabin and feck all thro the heater. (well known fault) .
So, i took out the aircon unit ,pointless having something there thats not needed and its weighty(worked well if anyone needs one) and now i need something to join up the fan to the heater so either......
a, a pipe from a non air-con equipped car or.....
b, altenatives, ducting etc etc.
Someone must have done this before.
Cheers.
Last edited by sidewaysreilly on Fri, 14 Dec 2012 9:20 +0000, edited 2 times in total.
Re: Heater pipe to connect fan to heater matrix.
Postby MX5Spares » Sat, 01 Dec 2012 7:06 +0000
I think I should have something for you may be from mk2 .Any mk1,s I have recently are jap,s. Dumped a shell this morning for recycling with heater intact !!!If you bring up car we can try it and maybe you could look at my tricky mx also.Robert .I am around till 4pm Sunday if that helps any or any evening from 5pm
Postby sidewaysreilly » Sat, 01 Dec 2012 9:22 +0000
might give you a shout next friday lad.
Postby MX5Spares » Sun, 02 Dec 2012 10:55 +0000
Grand but not till after 1.45pm .Thanks
Postby leamyj » Sun, 02 Dec 2012 2:39 +0000
autocheck wrote:Grand but not till after 1.45pm .Thanks
Jeez, you leave it quite late to get out of bed on a Friday :mrgreen: :mrgreen:
Postby MX5Spares » Sun, 02 Dec 2012 4:29 +0000
Some of us have to work .we need moneyto pay bills....kids are eating grass at the moment !!
Postby Steve » Sun, 02 Dec 2012 5:49 +0000
Sean, I took option A a few years ago, it works well.
Postby sidewaysreilly » Sun, 02 Dec 2012 6:46 +0000
Yeah, was thinking the same, keep it correct. Someone must have one somewhere.
Postby Steve » Mon, 03 Dec 2012 11:01 +0000
Heres one on ebay (autolink) if you don't find one locally.
Postby sidewaysreilly » Fri, 14 Dec 2012 8:52 +0000
anyone before i get a heat-gun to a wavin pipe???????
Postby MX5Spares » Fri, 14 Dec 2012 8:56 +0000
Eh ????
Postby sidewaysreilly » Fri, 14 Dec 2012 9:16 +0000
make a pipe to suit out of wavin, or do you have one lad??????
Postby sidewaysreilly » Sat, 15 Dec 2012 4:45 +0000
All sorted. Took out the evaporator unit and gutted it, taped up any holes and used new double-sided foam tape around the joints. Perfect now, loads of heat......passed nct with flyin colours also.
