Engine Swap
Engine Swap
Postby back_in_black » Thu, 10 Jan 2013 11:18 +0000
Looking for a 1.6 enine with or without gear box. Only willing to swap for a 1.6 auto with or without gearbox with 93000km on it. I'm not sure but I think the auto engine can be good for a turbo build. The cam shafts are different to provide more torque at lower rpm. Might suit someone here.
back_in_black
Re: Engine Swap
Postby MX5Spares » Fri, 11 Jan 2013 8:07 +0000
Fit the engine u have ??
Re: Engine Swap
Postby rhysmate » Fri, 11 Jan 2013 9:06 +0000
why dont you just plug a manual box onto the auto engine?
rhysmate
Re: Engine Swap
Postby back_in_black » Fri, 11 Jan 2013 12:08 +0000
The auto engine has a few different bits on the intake manifold and has no flywheel. Not a big deal but i looking to do a complete engine rebuild with everything finished and then change it out. The other thing is the auto engine dosent give the same performance at higher rpm.
back_in_black
Re: Engine Swap
Postby rhysmate » Fri, 11 Jan 2013 2:14 +0000
I see. i know a man with a 1.6 for sale ill call him
rhysmate
Re: Engine Swap
Postby Merlot man » Tue, 15 Jan 2013 3:45 +0000
Hello Alan ,I have a 1.6 engine, can give you the intake manifold and fly weel if that helps you , no charge.
What about going up to a 1.8 ? I'm sure robert has plenty of these.
Either way hope you get sorted ,are you buliding another mx5 ?
Brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
Re: Engine Swap
Postby back_in_black » Wed, 16 Jan 2013 12:09 +0000
Hi Brian. That sounds great. I'm sure I'll find one or two bits around the shed to trade with you! Any plans on getting the aircon in? Hope to fix the car up and make the next cars and coffee in Limerick. Chat to you about it then if ur there.
Thanks again
back_in_black
Re: Engine Swap
Postby Merlot man » Wed, 16 Jan 2013 11:21 +0000
Can bring manifold and flywheel to limerick next time ,can you just remind me by text or pm ,thanks hope they work out
Brian
93 na s ltd
Merlot man
