Door glass replacememt
Postby Merlot man » Mon, 25 Feb 2013 3:02 +0000
Hello all ,
I'm looking to change me door glass soon with clean ones ,mine are scratched,I think from old dried up weather strips ,have new ones fitted.
Any points to be looking out for and can someone recommend a good window lubricant [steady!] for the runners .The car has electric windows.
Thanks in advance
Brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
Re: Door glass replacememt
Postby leamyj » Mon, 25 Feb 2013 3:28 +0000
I think that there's some sort of a white grease on the runners...don't know what it's called, but all you need do is periodically take the door cards off and check the state of the lubrication on the runners...Someone here is bound to put a name to it!
Postby Merlot man » Mon, 25 Feb 2013 7:34 +0000
Are you talking about white lithium grease? I've used it in the past and found it good but I was wondering if there is a special grease for window runners .
Thanks for the reply
Brian
93 na s ltd
Merlot man
Postby leamyj » Mon, 25 Feb 2013 7:38 +0000
lithium grease...that's the one....not aware of any other for this job.
Postby MX5Spares » Mon, 25 Feb 2013 7:51 +0000
The product must not be petroleum based anyway otherwise it will react against the plastic window wheels that run in the tracks. I thiink vaseline is the best for it and always handy to have in the car.....in case you get lucky !!!
Postby Merlot man » Mon, 25 Feb 2013 8:01 +0000
Thanks for that Rob ,afraid my getting lucky days alas are well over!
Is vaseline not petroleum jelly ie. IS petroleum based?
Can someone help clear this up?
Brian
93 na s ltd
Merlot man
Postby Steve » Mon, 25 Feb 2013 9:58 +0000
I've used copper grease in the past, seemed to work ok.
Postby Fergus » Tue, 26 Feb 2013 12:54 +0000
This thread is going off the window rails - you'll all end up with using KY Gelly :mrgreen:
Lithium Grease is the only one to use on the two window runners as it won't bung up later and turn into cement which ends up snapping the cables. Do not use any type of silicone spray as it dries up and your cables WILL break.
Postby sidewaysreilly » Tue, 26 Feb 2013 2:36 +0000
does KY Jelly not dry up if your not quick enough..........?
Postby leamyj » Tue, 26 Feb 2013 7:50 +0000
sidewaysreilly wrote:does KY Jelly not dry up if your not quick enough..........?
:mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Nice one Mr Reilly :thumright:
Postby Merlot man » Tue, 26 Feb 2013 3:22 +0000
Thanks for all the comments lads .........and the advice about the window rails!
Brian
93 na s ltd
Merlot man
