Clutch Judder in 1st & Reverse
Postby Diarmuid » Fri, 27 Sep 2013 10:46 +0000
Since I got my car I have noticed a small judder when taking off in First or Reverse, the clutch seems fine otherwise but this judder is annoying. Is there anything I can check or look at to see whats causing it or do I have to go order a new clutch?
Diarmuid
Re: Clutch Judder in 1st & Reverse
Postby MX5Spares » Fri, 27 Sep 2013 2:58 +0000
Generally you will need new clutch as the pressure plate is probably buckled but you could check the univ joints on the driveshagt for play/slack just in case.New clutch ( good quality) is around 150e plus labour approx 250e
Postby scallan » Fri, 27 Sep 2013 4:24 +0000
If its not a standard clutch it can aswel my stage 3 does it the whole time
scallan
Postby Diarmuid » Fri, 27 Sep 2013 5:25 +0000
Thanks guys, I'm going to see if it gets any worse and then take the plunge and order a new one.
Diarmuid
Postby rhysmate » Sat, 28 Sep 2013 12:42 +0000
Could it be the slave cylinder? Did you check that?
rhysmate
Postby Randy » Sat, 28 Sep 2013 4:12 +0000
Brakes could be another thing to check possibly?
Randy
Postby Diarmuid » Sat, 28 Sep 2013 8:00 +0000
I haven't really checked anything major yet, the weird thing is that it is a bit sporadic so could be a leak on the clutch itself. But I'll try and get a look at the master cylinder as well.
Diarmuid
Postby Diarmuid » Mon, 30 Sep 2013 1:21 +0000
I have decided just to get the clutch done, the cheapest I have been quoted for just the clutch part is €250, that seems high. what you guys think?
Diarmuid
Postby MX5Spares » Mon, 30 Sep 2013 7:20 +0000
We acn do full job incl all parts (4 parts plus oils etc) required for incl labour but I can save on parts if you want to use reconditioned (not recommended) 086 8226506
Postby Diarmuid » Mon, 30 Sep 2013 8:52 +0000
autocheck wrote:We acn do full job incl all parts (4 parts plus oils etc) required for incl labour but I can save on parts if you want to use reconditioned (not recommended) 086 8226506
Thanks Robert, I have some meetings in Cork this week so need it done ASAP, I got a clutch for €200 and the garage next to me will fit it for €150. Well at least I don't have to worry about it for a while. The shopping list for this car this week has been astronomical (but mostly nice things), but I have to say it is looking pretty good now though....
Diarmuid
Postby MX5Spares » Fri, 04 Oct 2013 7:13 +0000
Ah 350e all in is good price for complete job incl parts especially for NEW parts
