Side Mounted Reg bracket
Postby MX5Steve » Sun, 25 May 2008 9:22 +0000
So i decided to make up a side mounting reg bracket, seen as I backed into my own car and damaged the plinth :oops: :oops: :oops:
Heres the drawing I found on the english OC site!
So I went and made me a cardboard cutout to see how she looked
This mount turn out to be very low. So i did a bit of a redesign!
Here you can see that I used two M8 38mm washers to clamp it to the tow hook....
The height and distance from the bumper was just right. But I used only 0.5mm steel so she was bouncing alot.
So i TRIED to stiffen it.......
This didn't work, so I have redrawn the bracket and I'm going to get it made as specified in the original UK OC drawing at 1/8 inch or 3mm.
see dummy reg print off stuck to the bracket below.....
Here's my final design if anyone wants a go for themselves.
It may look messy attached to the hook but all this is covered by the plate.
Can't wait now to get it made.
I know I could have paid €40 euro off autolink for a cusco one, but then I wouldn't have had the enjoyment of making one to fit, and at least now I know exactly what I'll get...... 8) 8) 8)
Postby mx5ash » Sun, 25 May 2008 9:38 +0000
Fair play to you mate, Excellent work. Hope it looks good when its on.
Re: Side Mounted Reg bracket
Postby sspecdave » Tue, 27 May 2008 11:40 +0000
[quote="coughlanstephen"].....
8) Looks pretty good Steve 8)
